Symptoms of internal engine damage?
Old May 2, 2005 | 08:47 AM
nikkev's Avatar
Default Symptoms of internal engine damage?
First of all, it's a 1998 Z28 A4 with lid/MAC's/TCI 4000 stall/bullet muffler on the end of the i-pipe.
Ok, here is the long drawn out story of my car. (I am seriously thinking of trading it in after all this!). My car has had a rough idle ever since I have owned it,so I was assuming that is normal for a LS1. The car pulled 305rwhp on the dyno with a lid, headers, and catback through a 3200 stall while pulling 8.1's. Anyway, last time I dyno'd, I pulled an amazing 225rwhp. Now, my transmission was on it's last legs at the time so we assumed it was the tranny slipping. Swapped in new tranny along with a 4,000 stall and then ran the car at the track to make sure I got that power back (dyno is 4 hours away). I did not get that power back. I usually run a 8.1 or 8.0 @ 86-87 mph. Well, this Friday, I ran a 8.8 @ 76mph! I did break loose every shift and almost hit the wall on the 2-3 shift (bald nittos), BUT it shouldn't be THAT bad of a mph, should it? I JUST changed the plugs (went with Bosch platinums, then read about them on here, oops) I pulled out NGK TR 5's (not 55's) and some looked perfect (brownish), some looked lean (white) and two looked reddish (not sure what that means). Jeff Creech (my tuner) thinks something in my motor is giving out even though it looked great on the dyno run that only showed me putting down 225rwhp (all engine readings were good). Now my question is where do I start looking? The coolant looks good, the oil isn't frothy, and the car cranks and runs fine. Could it be a head gasket leak even though it doesn't overheat and there are no other signs? Will a compression test alone tell me everything I need to know or will I need to do a leakdown test as well? If it could be valve springs or something, should I just put the new comp 918's on and see if that helps? Or do I trade it in on something else? LOL, and before you say stroke it, remember that I don't have a big budget! There is no suction or blowing coming from the oil cap, so what do I check now? There was a bad vibration at 1100 RPM's, but I rotated my stall one hole and it went away. Another change I made was that I went from a 3" I-pipe with a cut-out to a 3" I-pipe with a bullet super turbo muffler that dumps right in front of the axle. Could this be THAT big of a restriction? Thanks for any help.
PS
This is a long list of wierd things that have happened in my car. Local guys think it's possessed!
Old May 2, 2005 | 10:18 AM
MrDude_1's Avatar
car go slow.
lol, j/k kevin.. ttt for ya.
Old May 2, 2005 | 10:24 AM
zamboxl's Avatar
PS
damn saounds like me man i had bad luck with my carever since i got it to. if it's posses man and you are short on funds just cut it loose man and get your self a newer one.
Old May 2, 2005 | 11:06 AM
nikkev's Avatar
Tell me about it! The car ran stronger bone stock than it did with a ton of mods to include computer tuning on a dyno Thinking about abandoning it and trying to get a newer one if I can get a good interest rate. Only problem is, this one will be paid off within a year
Old May 2, 2005 | 11:08 AM
nikkev's Avatar
Originally Posted by MrDude_1
car go slow.
Dude, I am about STUMPED with this car. Everything I check checks good, even with a Tech II scanner from GM. The only thing is that it won't get up and go!
Old May 2, 2005 | 11:15 AM
1999T/A's Avatar
Have you checked for false knock ? Do a compression test for sure and post up the numbers .
Old May 2, 2005 | 11:35 AM
nikkev's Avatar
Will try that after work..... What will false knock cause? I do have a lot of knock retard showing in A-tap, but everything else is fine. Could it be a rusted knock sensor or something? Would this cause me to be THAT much down on power?
Old May 2, 2005 | 11:41 AM
MrDude_1's Avatar
dude, ive scanned your car...you've scanned it... milkman has scanned it.... the computer cant tell you everything.
its time to start looking at mechanical things.
id start with doing a compression and leakdown test...
Old May 2, 2005 | 11:49 AM
nikkev's Avatar
So why didn't you break out the compression tester when I was at Todd's house? Oh yeah, we didn't have one! LOL, so now I have to go buy one. If the compression tests are all good, do I need to do a leakdown test?
Old May 2, 2005 | 11:56 AM
MrDude_1's Avatar
might as well do it at the same time since the spark plugs are a bitch to get to.. ask PJ or Joey or Jeff... someone probly already has one you can barrow...
also, stick a vac gauge on it while its idling... just to see what its upto.
zamboxl's Avatar
bingo we found our culprit the 98 cars are renound for having bad knock sensors this causes the computer to pull alot of timing killing your performance, i never heard of it as bad as you have it but you did say the comp was pulling alot of timing. easy fix just change the knock sensors.
Old May 2, 2005 | 11:59 AM
nikkev's Avatar
A-tap has shown as much as 4.1* of knock retard driving at 1400 RPM's and 15.6* at 5800.. I will do a compression check AND check the knock sensors. Thanks for the info.
Old May 2, 2005 | 12:00 PM
MrDude_1's Avatar
how come the PCM isnt showing a ton of knock retard?
Old May 2, 2005 | 12:02 PM
Brandon Boomhauer's Avatar
A-tap has shown as much as 14* of knock retard driving at 1400 RPM's. I will do a compression check AND check the knock sensors. Thanks for the info.
holy hell thats alot at 1400rpm
Old May 2, 2005 | 12:13 PM
MrDude_1's Avatar
1. why didnt you tell me that sooner?
2. why didnt that show up when i was riding in your car the othernight?
armed with this new knowlege, i say, go replace your knock sensors... lol.
nikkev's Avatar
It doesn't show it all the time, only while driving. And I don't think you had it turned on that night did you?
Old May 2, 2005 | 12:18 PM
nikkev's Avatar
Well, honestly I had forgotten about it It was when I was having lots of misfire issues. I changed out my wires and the misfires went away. I totally forgot about the knock retard as I assumed it was related to the misfires. And I didn't think you had that parameter running the other night?
Old May 2, 2005 | 12:27 PM
nikkev's Avatar
OOPs! My bad, it was 4.1* @ 1400 RPM's and 15.6* @ 5800 RPM's. I just looked back at my logs.
Old May 2, 2005 | 12:28 PM
MrDude_1's Avatar
it was one of the things i was watching...
anyhoo, i did a search for you..
the GM part number for the knock sensor is :10456222
$74.45 for TWO at GMpartsdirect.com
the Equivalent Part Number:
Delco 213-298
GP Sorensen KS116
you can probly get the GP one at advance... athough id goto Parks(main store) and see if they have the delco one in stock.
Old May 2, 2005 | 12:34 PM
nikkev's Avatar
Delco 213-298
GP Sorensen KS116
I e-mailed Jeff to see if my knock sensors were turned off (although I don't know why they would be) and I will run A-tap on the car again today to make sure I still have the knock retard. Can I tell if the sensors are bad by just pulling the intake? Will they be good if they look good? I don't want to just throw parts at this car anymore, i want it to run again!
