Which pushrods to install FM11 w/stock heads?
Old 07-07-2005, 07:20 AM
KB99WS6's Avatar
Default Which pushrods to install FM11 w/stock heads?
Going to get either an FM11 or FM13 cam. I already have a PRC Gold dual spring kit, and need to know which pushrods to get. Also, should I get one of those Thunder racing cam install kits that come with all the gaskets in one shot, or is there a better way to go about it?
Thanks,
Kevin
Old 07-07-2005, 09:43 AM
PREDATOR-Z's Avatar
7.40 on stock heads and gasket
Old 07-07-2005, 10:21 AM
KB99WS6's Avatar
Thats what I thought, thanks. What about gaskets? Just trying to figure out what all I need I guess...
Old 07-07-2005, 02:56 PM
PREDATOR-Z's Avatar
If you are not taking the heads off (like to change lifters) then just the basic gasket bolt kit (water pump gaskets, front seal, head cover gasket, pulley bolt)
Also what year is your car? perhaps you're going to need an oil pump and O rings + a timing chain (LS2)
Old 07-07-2005, 03:46 PM
KB99WS6's Avatar
my car is a 99, but only has 29k miles on it. I was hoping I can get away with continuing to use the stock oil pump and t-chain
Old 07-07-2005, 10:37 PM
'02 SLP#686's Avatar
Stock pump would be ok if you have good pressure now, the LS2 chain is rather inexpensive (really), for the price it is a good piece of mind
Old 07-08-2005, 01:37 AM
PREDATOR-Z's Avatar
Since it is a 99, i would change the chain (get LS2, it is the official replacement chain now) and at least a replacement pump (it is the updated LS6 pump)
Less than a $100 for both from SDPC>>>>> sponsor.
Old 07-08-2005, 01:41 AM
PunkNPonys's Avatar
Very nice info. I will be doing the same thing here pretty soon. Not to steal the thread or anything but what cam would you guys recommend out of the 2 with N2O? I cant decide which one to go with. Well let me know how the install goes. Thanks
Old 07-08-2005, 01:45 AM
PunkNPonys's Avatar
Oil Pump, LS1, Blueprinted and Ported
Price: $149.95
Part # SD3964B
Is that the oil pump your talking about?
Old 07-08-2005, 01:48 AM
PREDATOR-Z's Avatar
Both FM 11 and FM 13 will do well on nitrous, 114 lsa being preferable for bigger shots.
Old 07-08-2005, 01:49 AM
PREDATOR-Z's Avatar
Price: $149.95
Part # SD3964B
That is a ported pump, a standard replacement (ie LS6 pump) is plenty.
Old 07-08-2005, 02:05 AM
PunkNPonys's Avatar
Where can i get this one? And if you could send me the link for the right chain? THanks
Old 07-08-2005, 02:52 AM
PREDATOR-Z's Avatar
http://www.sdpc2000.com/cart.asp?act...tart&catid=873
They carry both and have the best prices.
Ask for a LS2 chain and a stock LS6 pump
Old 07-08-2005, 06:55 AM
98A4LS1's Avatar
I ordered the above from SD recently, here are the part numbers I received:
LS2 chain: 12586482 (Made in France)
LS6 oil pump: 12586665 on box; 12556436 on oil pump
HTH
Old 07-08-2005, 07:04 AM
KB99WS6's Avatar
HTH
Good info guys, thanks
Old 07-10-2005, 12:46 PM
KB99WS6's Avatar
Ok so all I need is
-Cam
-PRC spring kit
-TR 7.40 Pushrods
-TR Gasket swap kit
-LS2 chain
-LS2 oil pump
Anyhting else I should get? Does anyone ever replace the actual vavles with stronger ones??
Old 07-10-2005, 03:27 PM
AaronR's Avatar
I need the same parts for my install,cant find any pump on SDPC other than the one for 150?l
Old 07-10-2005, 04:16 PM
cyphur's Avatar
Call Kris Jones @! SDPC tomorrow and ask him for an LS6 pump, let him know you're doing a cam install so he knows exactly what you're talkin about. It should only be ~70 bucks or so. He'll take care of you.
Old 07-11-2005, 08:50 PM
Dustin's Avatar
here is the link for the pump
http://www.sdpc2000.com/search.asp?s...pump&doquery=1
Old 07-11-2005, 10:10 PM
KB99WS6's Avatar
Well that pump is $80, predator said you could get both the pump and the timing chain for less than $100? That would mean the chain is $19 or less??
