I have only seen one double roller Rollmaster break, and it was because it was installed wrong, wasnt installed dot to dot and caused massive PTV contact |
I broke my stock LS1 timing chain a few years ago while getting on the gas to merge into highway traffic. It happened in the desert halfway between Phoenix and LA with the family on board headed to Disneyland. The car was a bit rough when I bought it in 2000 - it had been a lease and already had 48k miles on it (I don't think it was well cared for). Fortunately, my extended warranty mostly covered installing a new motor. Among a lot of other damage (broken pistons, rod, block, and valves), there was a rod with broken bolts. The GM tech was not sure if the chain snapped from the shock of the rod cap coming off or if the snapping chain and resultant shock of valves hitting pistons caused the chain to snap. I think the chain went first but it could have been the rod first. :) Steve |
I have had two stock chains that I have seen broken here at the shop. One was a lower mileage Z06 with a Procharger on board and was run very hard. Still had stock springs at the time. Possibly missed a shift and had piston to valve contact first......definitely after. No other damage besides notched pistons and a few bent valves. Ran fine after a new chain and a few used stock valves. Second was a higher mileage SS M6 that is also run pretty hard. It was recently gone into and has dual springs with 125lb seat pressure. Nothing too bad. Again, a new chain and cylinder head repair and she should be fine. Over the past 7-8 years dealing with the LSx engines, these are the only two chain failures I have seen. Most failures, mainly stock chains, I hear of have 140+lbs of seat pressure and run over 6600RPM quite a bit. Hope this helps. Mike Norris |
had a JWIS chain with hex-adjust gears in last years motor. 250+ seat pressure, not sure on the open pressure (ISKY springs), shifting at 8k. Had a lifter explode, still ran, didn't know it was broke actually ;) Exhaust covered up alot of engine noise. Chain survived. |
i'll go back to my cube now ;) |
On my '98 SS the stock timing chain broke when it had 55k miles on it. Running ported heads with a small duration Crane Cam and single springs at the time. I was on the highway and hit the nitrous button at WOT and the motor just died. Pulled over to the side of the road and it, never started again. Had catasrophic damage to all the valves and nice smileys on all the piston tops. Had to tow my car from Florida to Houston. Not good when this happens so far from home. |
Based on the responses so far, the stock chain looks pretty solid. How would stiffer springs, like many here run, affect overall life since it appears that stouter springs may help bring on its demise. Something like Comp 918's or the Cranes? |
Originally Posted by y2khawk i'll go back to my cube now ;) Philip S. |
Is the LS2 chain supposed to be stronger than the stock LS1 chain. I plan on running an F11 cam w/patriot dual golds & putting in a new LS2 chain. Wondering if I should get something stronger?? |
We use the jwis chain also. I have had two broken ones under same basic scenario. Both road race 346's. 1 had lost third gear early in the race (3 hour Motorola cup). Constant driving up past 3900-4100rpm caused by skipping from second to fourth. 2 had 1 lap lead 1 hour into race. They started shifting at 5000 to slow down lap times. This brought them into the same rev zone the engine does not like. Both chains had multiple locked up kinked links, with one link broken. After we tested with different durometer rings we found a ring setup that helped to control the bad vibes in that zone. My turbo engine has this chain with a stock upper gear and a cloyes lower. The springs are 350+ on seat 950 open. The shift point is 8900rpm. So far so good. Kurt |
| All times are GMT -5. The time now is 01:20 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
