Why is my LS1 getting horrible gas mileage?
Old 08-01-2005, 02:15 PM
LS1Pimp's Avatar
Default Why is my LS1 getting horrible gas mileage?
I drive a 1998 Trans Am WS6 Automatic, and the gas mileage is horrendous. I usually get 8-10 miles a gallon. Usually 130-140 miles a TANK. I don't drive it hard at all, im very easy on the gas. What usually causes a car like that to be getting horrible gas mileage? LS1's should be getting 15-20, not freaking 8mpg. Its getting really annoying and expensive having to refill the car every 3-4 days.
Old 08-01-2005, 02:17 PM
King James's Avatar
What mods? What maintenance have you done? More info is needed.
Old 08-01-2005, 02:19 PM
john3daly's Avatar
Yea, I was getting about 10mpg before the tranny swap. Now that I only have 4 gears, it's gonna be interesting to see what I get now.
Do you have a big cam? That's when I lost mine.
Old 08-01-2005, 02:20 PM
LS1Pimp's Avatar
Just basic bolt-ons
1.Hypertech programming
2. FIPK
3. Corsa Exhaust
4. Subframes/LCA's
5. Descreened MAF
6. 3.73's
Just oil changes basiaclly.
Old 08-01-2005, 02:30 PM
LS1 Tech Administrator
Patrick G's Avatar
Descreened MAF and HPP3 tuning are not great combos for WOT performance, but I don't think they're contributing for your poor fuel economy. Biggest contributors to bad gas mileage are usually cheap to replace:
Spark plugs
O2 sensors (bad ones will screw you).
MAP sensor
Dirty MAF hot wire elements (clean them).
Check and replace these items and check out your fuel economy again.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 08-01-2005, 03:25 PM
4mula's Avatar
the 3.73 rear gear isnt helping much on milage
Old 08-01-2005, 06:51 PM
Casperws6's Avatar
Spark plugs
MAP sensor
Old 08-01-2005, 07:11 PM
Grave's Avatar
Ha... yeah, same here. I get about 160 some-odd miles out of 3/4 of a tank.
Old 08-01-2005, 07:13 PM
TAQuickness's Avatar
Do you have a scan tool? Would be good to see a log of your commanded AFR, LTFT's, and S1 O2 voltages.
it's not hurting much either. I'm getting ~20mpg with mine.
Old 08-01-2005, 07:14 PM
noah89's Avatar
I'm running 4.10's with a 12 bolt and I average close to 19 mpg. Lots of quick runs through 1 and 2. I can't help it. I always hit 150 miles at the mid tank readings. Something is very wrong.
Old 08-01-2005, 07:17 PM
Phoenix 5.7's Avatar
somethings gotta be wrong. even with those gears it shouldn't be that bad. im near stock, but my car is running rich and i still get no worse than 17 ever
Old 08-01-2005, 07:19 PM
2000 Tran Zam's Avatar
also check your fuel filter. if that is clogged then that could be the culprit.
its recommended to change it out every 15k miles or so.
check the air filter, make sure your not misfiring, possibly from bad plugs, wires, etc...
Old 08-01-2005, 07:28 PM
pdd
pdd's Avatar
im in the same boat. i get about 12mpg
Old 08-01-2005, 07:35 PM
Grave's Avatar
If it helps any... my A/F ratio is around 13.0:1 in low/mid RPMs until 4000, and around 12.5:1 around higher RPMs.
I'm willing to bet my it's because I have a few small leaks around on my headers where the collector and cat meet. Maybe the outside air is making the O2 sensor think it's running lean and dumps more fuel?
Other than that... I don't know why it does what it does. It runs like a champ. I just have the standard issue entry level bolt-on mods, nothing internal (yet).
Old 08-01-2005, 09:33 PM
Grimes's Avatar
How many miles on the car? If it's a high mileage 98 i'd say change out your front 02 sensors definitely.
Old 08-01-2005, 10:38 PM
black_ws6's Avatar
I was getting 15MPG then I hooked up HP tuners and realized that I had a problem with an O2 sensor and they were running in the high 800's constantly. I ended up changing out a bad O2 extension and I am back up to 20.5 MPG.
Old 08-01-2005, 11:48 PM
mxmccarter2401's Avatar
Spark plugs
MAP sensor
why is the descreened maf and hpp3 bad for wot performance.
Old 08-02-2005, 05:42 AM
PREDATOR-Z's Avatar
All the HPP3 does is copy the high octane tables to the lower octane tables. Usually makes you run too lean, a descreaned MAF on an auto will just accentuate that.
Old 08-02-2005, 06:13 AM
FiveSevenEagle's Avatar
ive been in this 2 , changed the spark plugs and O2 sensor , and cleaned the intake manifolds and the maf ... it much improved ,
Old 08-02-2005, 06:17 AM
PonchoFan's Avatar
I'm getting 15-18 mpg with the mods in sig.
I suggest a dyno tune.
Quick Reply: Why is my LS1 getting horrible gas mileage?
