how much power can the ls1's handle i have a 00 ls1 in my s10. it is turbocharged running 6 psi. i was wondering how much psi the ls1's can handle on stock internals. any help is appreciated. |
Originally Posted by s10v8 i have a 00 ls1 in my s10. it is turbocharged running 6 psi. i was wondering how much psi the ls1's can handle on stock internals. any help is appreciated. |
sorry i posted this in the wrong forum. thanks for the advice. anyone else ever do more then that? |
Originally Posted by s10v8 sorry i posted this in the wrong forum. thanks for the advice. anyone else ever do more then that? ls1 is all aluminum, remember? aluminum can't safely handle more than 8 psi |
Originally Posted by firechicken2k sure, with forged internals. ls1 is all aluminum, remember? aluminum can't safely handle more than 8 psi |
yea 8 is about the limit on stock internal parts, than its forged time... |
ls1 motorsports successfully ran 17 psi on a stock internal motor, stock heads, etc. motor had 123k+ miles on it and like almost 150 dyno passes and still held together. they actually pulled the motor before it blew up just to swap in a 348. |
Depends on the tune |
Depends on tuning, compression, and fuel.. But most guys grenade with more than 10lbs.. With 6lbs it should last for long time! |
Originally Posted by 1QuickT-A Depends on tuning, compression, and fuel.. But most guys grenade with more than 10lbs.. With 6lbs it should last for long time! s10v8, you should PM Harlan . . . he knows a thing or two about boost :D |
| All times are GMT -5. The time now is 07:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
