HELP!!! Car won't start Just talked to my dad on the phone, and he told me he had the car running while he was finishing cutting the grass. He said he went to check on it and it was really hot. He turned it off, and then tried to restart it, and it will only crank. Anyone have a clue as to what it could be? My dad isn't mechanically inclined, and I am in Africa so i can't give any better description. Had AFR heads, LS6 pump, SVO 30lbs, LS-2 chain, Ported TB installed about 2 months ago. Any help is appreciated. |
If the fuel ran low, or you let it run very low often, it could burn out the fuel pump. This happened to me on my '97 WS6! arg! |
Just had a ported LS6 pump put on 2 months ago, and the car hasn't had 1000 miles put on it since. Looks like a SES light is on, so I need to find the way to check the code on the DIC and somehow explain it to my dad. I guess this all started about 2 days ago. |
Had my dad check the codes. Looks like I have a couple 1255 1064, 1026, 1096 codes. Which are all loss of PCM BCM signal codes. Wondering if this all goes back to the battery I had die on me. |
Had my dad check the codes. Looks like I have a couple 1255 1064, 1026, 1096 codes. Which are all loss of PCM BCM signal codes. Wondering if this all goes back to the battery I had die on me. Also PO336 crankshaft position sensor. |
| All times are GMT -5. The time now is 03:16 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
