FM13 with full exhaust I'm wondering how the F13 will respond to a car with LT's, Catted Y, and a catback. Almost all the numbers I see are on cars with duals. While they make impressive #'s w/ duals, the lower lift on the exhaust side of the cam sorta worries me w/ a full exhaust setup. So does anyone have a cat/Ypipe setup w/ the cam that can post numbers, or a graph would be best. Or if you have a graph of the F13 on a 112 or 114 just post up, i'd like to see how the different LSA affects the curves as well. I know the 112 will peak alil higher ... |
I think your car would pick up a bit going to the F13, probably about 10 on both hp and tq. |
I tuned a car that made 393 rwhp on 115,000 mile bottom end. It was through FLPs (1 3/4) and Borla. |
I put down 391RWHP (F13/114LSA) w/SLP longtubes into random tech cats and through an SLP 3" y-pipe. Dynoed in about 95+ degree weather in Arizona. |
99BackNBlackZ28 - Nice #'s ... i guess i was worrying for nothing. Thanks guys Mine will probably be thru RT cats as well, and a custom 3" pipe that should flow very well. So I guess I shouldn't have any problems maintaing my current power levels. |
https://ls1tech.com/forums/showthrea...&highlight=F13 http://www.norcal-ls1.com/multimedia..._408_Small.jpg TTS Long Tubes, 2.5” Y-Pipe (non mandrel bend), Megaflow |
Originally Posted by Tech I tuned a car that made 393 rwhp on 115,000 mile bottom end. It was through FLPs (1 3/4) and Borla. |
how about 400 hp and 390 tq hookers, nocats, magnaflow, 6speed, stock heads |
Originally Posted by jerflash how about 400 hp and 390 tq hookers, nocats, magnaflow, 6speed, stock heads Is that a 112+2 or +4? Nice numbers btw, if i can hit right at or just a hair under 400 w/ torque like that I'd be very pleased. |
A 112 LSA is for M6 cars and the 114 LSA is for automaitic cars. |
See sig. And this was with a mail-order tune, in 95 degree, humid ass Florida weather. I got the 114 LSA because mine is a DD and I wanted as good as possible streetability. I'm sure with a full tune I could get closer to 400 rwhp. Drew |
Originally Posted by mochiles See sig. And this was with a mail-order tune, in 95 degree, humid ass Florida weather. I got the 114 LSA because mine is a DD and I wanted as good as possible streetability. I'm sure with a full tune I could get closer to 400 rwhp. Drew |
the 400/390 with with a 112+4 but i was thinking if i ever had it apart i might retard it two degrees just to get the peak a lil higher in the rpm band i dont think i would want anyother cam but this cam its perfect for what im doing great power, drives like stock with a good tune, and with a set of good heads and a 90/90 you lookin at 450 to the wheels maybe more |
jerflash - what rpm's did your hp and tq peak at? |
from 6100-6300 the hp is pretty much flat and thats the peak tq peak is 4700 |
i have an a4 and i would rather go w/ the 112. is that really going to make it that muc better if i go 114??? |
The way the 112 will handle itself in an A4 is in the tune. But the 114 will have more vacuum which is a plus with A4s and brakes. |
© 2024 MH Sub I, LLC dba Internet Brands
