LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Adjustable Harland Sharp 1.7's (https://ls1tech.com/forums/generation-iii-internal-engine/389916-adjustable-harland-sharp-1-7s.html)
98WhiteDevil Oct 4, 2005 08:03 AM
I found needle bearins in my oil pan, so I picked up a set of Adjustable Harland Sharp 1.7 rockers. Could somebody give me a step by step process of installing these and setting the lash. I'm unsure of how to do this since our cars have hydraulic lifters. I have a 98 Trans Am, the engine is pretty much stock except for an LS6 intake and PCV kit.
rons 00z Oct 4, 2005 09:41 AM
i didnt think harlands were adjustable?
PREDATOR-Z Oct 4, 2005 09:56 AM
Unless they have a new model, HS are non adjustable.
Just use TDC method and 22ft/lbs
98WhiteDevil Oct 4, 2005 10:08 AM
Go to Speedinc.com that's where I bought mine from, HS has new adjustable 1.7 rockers.
PREDATOR-Z Oct 4, 2005 11:57 AM
Not much experience with these around here. Perhaps someone can chime in.
Probably will have to grind your valvecovers for clearance and perhaps the head too.
98 perimeter heads are renown to have clearance issues with all aftermarket rockers.
If I were you, I would just send those back and get them to do the LS1/LS6 "upgrade on the stockers". much less headaches.
Gunnar@Patriot Oct 4, 2005 12:33 PM
They do make 1.7 adjustable.If you need any help with them, give Randy JR. @ Harland Sharp a call at 440-238-3260, he is a great guy to deal with.
Bryan @ Speed Inc. Oct 4, 2005 12:40 PM
speedinc girl kelly is my woman :naughty:
Bryan @ Speed Inc. Oct 4, 2005 12:42 PM
gunnar... why aren't you plugging the patriot shaft mounted adjustable rockers that fit under stock valve covers??? :)
Gunnar@Patriot Oct 4, 2005 12:47 PM
The Patriot shaft mounts will not fit under a stock cover.
© 2026 MH Sub I, LLC dba Internet Brands
