Heres the combo I came up with, whatcha think?
2002 WS6. I'm putting on pacesetter lt's, tsp y pipe no cats, slp 3" dual/dual, vigilante 3000 stall, now the valve train putting in comp cams 921 springs, titanium retainers, comp cams magnum 1.75 rockers, hardenend pushrods, rollmaster hardenend timing chain, and texas speed torquer 2 cam specs are 232/234 .595/.598 and 112 LSA. How does this sound. From my research it should make good power, be very streetable and have a mean sounding idle.
Cam is a little big, so you'll lose a bit of low end tq. More "streetable" cams would be a bit closer to 224/224, but I guess with the 3000 stall it won't be too bad.
With a cam that big, I'd also stay with stock size rockers.
Also, no cats and SLP dual/dual are kinda contradictory. No cats is loud, rough, smelly, and raspy. Dual/dual is pretty much the quietest setup you can get.
Why not get high flow cats, and a more free flowing muffler? I'd bet it would sound much better. (it's what I've got, and I just heard my exhaust next to my 69 Mustang Mach 1 with a 390 big block, and my exhaust actually sounds just as good).
Other than that, it should be a pretty good, and affordable setup.
Originally Posted by mikeyZ06
I totally agree with the above response.
Well I liked the slp exhaust but if I have to i'll change the muffler. As far as the rockers the 1.75 should only add about .015 of lift. And comps I didn't see a stock ratio. But i'm gonna prolly go with a vigilante 3600 stall. Think that will go much better. Thanks, i'm open to any other coments too. Oh yeah and streetable I think is, not stalling and good vaccuum. I know it will have a chopy idle but I want that.
