800 RWHP goal??
800 RWHP goal??
alright everyone... let me know what you think... here is my new setup.
HPE 408 iron block stroker, rings gapped for a 250 shot, 11:1 compression
Patriot Stage 3 + heads, additional port work done after stage 3
Cam - 240 246 608 613 on a 110 LSA for some good torque and lope.
Vararam intake
FAST 90/90 intake manifold
NX direct port nitrous injection system (probably set at 300)
kooks stainless long tubes w/the larger primaries
the heads and cam are used and might be questionable for some but they put down VERY good power on my buddies car.. he put down....
440 RWHP NA on a stock bottom end
650 RWHP and 680 RWTQ on a 200 shot through a TNT F2 kit.. very good flowing and matched with each other..
im looking for a little bit over 500 RWHP naturally aspirated... with a 300 DP shot through the NX kit i should be very close to 800 RWHP correct???? id be happy with 700 RWHP on a 200 shot but if i can do 300 that would make me happy in pants hehe
Vararam intake
Did your buddies car have a 408 also? If he did then the numbers may be there. What upgrades to the transmission have you done to handle that power. Once you have it dynoed post up the numbers.
Holy **** he put down those numbers on a stock bottom end? Thats crazy! Did he blow his bottom end up? Yea you could def see 800 rwhp with a 408, that cam, those heads, and a 300 direct port shot. I would say you would be very close to that number. Good luck and let us know the results!
