What plugs for high compression NA motor?
When I had mine tuned, I had bosch +4's in and the tuner hated them because they run hot. He was having knock issues and recommended I use TR6's and tuned for them to be installed.Before I switched I was having 2000rpm pinging on 93. I installed the tr6's gapped to factory specs and runs great.Stupid me, the first time I put them in I left them at gapped at 37.The car would hardly start and was running like ****.So go back in and regap.Nothing like two plug changes after a hard day at work.
I'm at 10.8 cr
Jay
I'm at 10.8 cr
Jay
I wouldn't run TR6's on a stock non-nitrous engine, I've had them foul before when I was off the bottle. I would run TR6's if you close to 11:1 SCR, doubt they will foul with the higher cylinder pressure. TR55s would probably also be fine, might be trial and error to figure out what works best with your combo. I'd go with TR6's.
What you fellas think of AC Delco Iridiums ( .040-.045 gap) or other ? What gap should they be at for a cam only car if i should go w/ them?
TR55 N/A cam only would that cut it?
