Biggest cam on stock heads?
Old 12-06-2005, 09:20 PM
NIGHTMAREWS.6's Avatar
Default Biggest cam on stock heads?
Hey guys, whats the biggest cam i can safely get away with on stock heads, 2002 ws.6, current mods, flp long tubes, yank ss3600 stall, 3.73 gears,
currently i have 224/224 588/588 112, im looking to go to a bigger cam. i was looking at the f13 on a 114, but still hoping to have some chop, any suggestions? thanks.
Old 12-06-2005, 09:23 PM
GOGO's Avatar
Yeah that cam will work fine on stock heads. It is all relative to what you want. You can even go with the T-Rex if you wanted, but you will not the have the best drivability.
Old 12-06-2005, 10:00 PM
Studytime's Avatar
The TRex, I thought, was designed as a max effort cam for stock heads. The car it was tested in (during developement) had stock heads. Correct me if I'm wrong.
Ben T.
Old 12-07-2005, 11:59 AM
If i go with a larger cam, should i go with a 114 since its an A4, i want it to have some chop.
Old 12-07-2005, 12:43 PM
01Z0H6's Avatar
I too have an A4 "stock heads" with an RPM4 cam.. 232/236 .595 .601 @114+4
runs great.
Old 12-07-2005, 12:50 PM
Retired Street Racer
Matt D's Avatar
Here you go, THIS should answer all of your questions!
Old 12-07-2005, 01:11 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
T-Rex is only as tolerable as you are willing to let it be. I wouldnt hesitate to run it!
Old 12-07-2005, 04:27 PM
z28convert's Avatar
Not to hijack the thread but im in the same situation trying to find a cam with stock heads... "GOGO" you said,
How would it specifically affect drivability?
Old 12-07-2005, 04:36 PM
BADSZ28's Avatar
T-Rex seems to be the biggest production cam, but I have seen slightly larger custom grinds for stock heads without flycutting. I am not sure if G5X4 will fit stock heads or not. Increasing LSA will help idle and drivability slightly, but when you are in the 24Xs you should not be looking at drivability, you should be thinking where do I want my power band to be. If you want drivability go with something in the 22Xs generally, otherwise it is your own preferrence of what drivability is to you. For me, as long as it does not die and it starts up I could care less about the rest. It is all in the tune from there.
Old 12-07-2005, 05:36 PM
Nittany_marine's Avatar
G5X3. Its not the "biggest" cam you can go with, but its right up there....Me and my friend have em, and we each got over 400rwhp with bolt ons, and a tune. I started out with a 224, and upgraded to a G5X3, and I couldnt be happier.
Old 12-07-2005, 06:46 PM
GOGO's Avatar
The cam was designed to be a max effort cam on stock heads. Check out Thunder Racing--------->
Old 12-07-2005, 06:48 PM
GOGO's Avatar
BTW here are the specs on the cam for those that are interested. 242/248 .608/.612 110 LSA
