5.3 cam without changing valvesprings
Old Dec 12, 2005 | 01:15 PM
91redchevy's Avatar
Default 5.3 cam without changing valvesprings
What is the most lift and duration the stock valvesprings will handle? Wanted to
know before i made final cam decision. Thanks
Old Dec 12, 2005 | 01:47 PM
PREDATOR-Z's Avatar
You already have it (stock)
Old Dec 12, 2005 | 02:18 PM
SUTTERERMAN85's Avatar
you might as well put some ls6 ones in there for like $50 from SDPC. the stock ones suck. now you can run up to .550 safely with softer lobes will be fine.
Old Dec 12, 2005 | 02:21 PM
PREDATOR-Z's Avatar
You can run up to .570 safely and you can always shim for a little more with 02/up LS6 springs.
Old Dec 12, 2005 | 02:22 PM
91redchevy's Avatar
Thats what i had decided to do after i posted this question thanks for the quick replies.
All of you have been a great help so far.
