GMPP ASA vs. Lunati 230/237 :Roadrace setup...To be used with TEA Stage 1 5.7's
!LS1 11 Second Club
GM LS1 Street/Strip (1997 – UP) – Hydraulic Roller; Rough idle. Good Pro street or road race cam. Engine and computer modifications are required.
Part #: 55007LUN
Advertised Duration IN/EX: 298/286
Duration @.050 IN/EX: 230/237
Gross Valve Lift IN/EX: .544"/.543"
Lobe Sep Angle / Intake Ctr Line: 112/108
Valve Lash IN/EX: Hyd/Hyd
RPM Range: 2800-6000
Part #: 55007LUN
SDPC Part Number: 12480110
Manufacturer: GM Performance Parts
Advertised Duration Int. : Not Available
Advertised Duration Exh. : Not Available
Duration @ 0.050" (I/E) : 226/236
Lift (I/E) : 0.525"/0.525"
Lobe Separation : 110
RPM Range : 2500 - 6500
Cam Type : Hydraulic Roller
Heads would be 59cc TEA Stage 1 5.7's that flow:
.100 73.5
.200 144.4
.300 209.7
.400 252.3
.500 283.4
.550 296.1
.600 294.2
why not got with ...say tsp's torquer v.2
From everything i was researching it gets great low end torque and good top end pull.
Its something i have been considering for road race myself.
The two cams you listed would work, but wont make as much power IMO.
It would go great with those heads as well.
Originally Posted by SouthFL.02.SS
Thanks, but I don't want to use XE-r type lobes.
just giving ideas
-Chris
If you were building a road race motor with a 5.7L engine, you would probably be looking at something like a 244/248 to 256/260 depending on the track. You would be looking at an LSA of 106-107 and an ICL of +2-+4 (advanced). If it was in a competitive series you would want as much ramp as possible, pounding the intake and exhaust open with a fairly rapid intake close.
For a track day car you are already compromising the ramp and lift, presumably to reduce the stress on the valve train. So your only issue is street driving vs. track driving. Those race cams have a rumpa-rumpa idle and are very flat below 3000. Idles could be above 1000.
So your trade-off is street vs. track. If you are driving it to the track, you might want to leave the engine alone (except for oiling, cooling, and maintenance) and concentrate on the chassis and driver.
For performance mods I would concentrate on a linear and response throttle. Maybe AFR 205s with a 78mm tb and long tube headers with an x-pipe.
There is an LG testing video in one of these threads. Especially in the early part, he is on the throttle early and hard. That is easier to learn with less power and an easily modulated throttle.
!LS1 11 Second Club
I titled the thread "roadrace," to see what the immediate responses were.
The car will be a streetable car that will be used for lapping days at Homestead, Sebring, Moroso, etc. (I've seen you post in my RR thread, so I think you're familiar with my wants).
I've had a flat below 3K rpm with 1000rpm idle in my previous car, which was geared more fore drag, and I'm looking to build a trackable (RR) car that will have a broad powerband without having to spin past 6200rpm, albeit without sacrificing too much peak hp either. Friendly on the valvetrain too without having to put on too much sring. ASA meets my criteria. Just looking for a little bit more. The Lunati 230/237 seemed to fit the bill with its decent amount of duration and low lift.
Here's my other thread, detailing the entire setup:
https://ls1tech.com/forums/generation-iii-internal-engine/426384-south-s-planned-setup-5-7-tea-1-asa-ls6-tpis-oval-qtp-hvmc-etc-object-usable-power.html
I'm afraid of going with too much duration however, as the powerband would shift higher. I'd love to do a GM Cup style cam, but it would be a dog down low.
I'd like to step up to this Lunati grind:
GM LS1 Street/Strip (1997 – UP) – Hydraulic Roller; Rough idle. Good Drag race or road race cam only. Major engine and computer modifications are required
Advertised Duration IN/EX: 298/301
Duration @.050 IN/EX: 237/242
Gross Valve Lift IN/EX: .595"/.595"
RPM Range: 3000-6500
And one last thing, leaving the engine stock is not an option .. I know driver mod is much more important, but I get a kick out of planning out the internals.
!LS1 11 Second Club
Originally Posted by 11 Bravo
I have that cam NIB. Let me know if you want to take it off my hands.
Smaller cam like asa and get larger head cc. 215-225 cc makes great hp and get a smaller ish cam and alot of compression to make up the torque. You will want light clutch(fidanza alum) and nasty gears 411 +. Can i go to Sebring with you? I always wanted to go to Sebring. Ive been to Pocono, etc up here but those Fla tracks are next.
Ive talked to alot of RR guys and the 02+ zo6 is flat awesome with slicks so keep the zo6 specs in mind also. ( except for the cam, its too weenie for us fbod lope heads)
!LS1 11 Second Club
The heads would be 59cc 241's. Decent compression.
I learned to drive (I would now say that I really didn't know how to drive from the ages of 16-31, until I went to Skip Barber) at Sebring this year. The concrete barriers keep you honest and getting on the gas when coming out of the large turn on to the front straight is the most thilling experience I've had.
Must add light clutch to my list.
I may treat myself to Skip Barber soon.
No, 411+ gears will get you out of the smaller turns and compensate for any tq deficiancy. The big straights rarely would you run out of gear that i can think of. Walls and barriers are scary when can't afford to laugh and walk away. A guy rolled a gt3 Porsche at pocono and didnt think much of it. Thats when you can afford to RR I guess.
LS1 Tech Administrator
Sounds like you've been given some good advice from people with RR experience (go with more duration and faster ramps), but it seems you're more interested in having people support an idea that you already have in your head.
For my 2 cents, I'd say limit your intake valve closing point to 40 degrees ABDC at .050" if you want to keep your rpm under 6200 and finally, use the fastest ramp rates with the most lift you can afford to maximize torque production down low. Slow ramps make for lazy torque down low (compared to fast ramps with the same duration at .050").
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
!LS1 11 Second Club
Slow in, fast out.
!LS1 11 Second Club
This confuses the hell out of me.
http://i2.photobucket.com/albums/y2/TommyBoy74/scan.jpg
How does that explain the ASA's stellar tq curve?
Intake valve closing point is the biggest determiner to cylinder pressure and the rpm at which a cam makes peak power. The ASA cam (assuming it's ground on a 106ICL) has an IVC of 39 degrees ABDC at .050". This is pretty much where I recommended you keep your cam for best power below 6200. Coincidence? No, just good valve events. Go with faster ramps and watch the torque area under the curve increase.
