Help!! Is there a gasket.... Is there supposed to be a gasket between the oil pump and cylinder block? I'll give reasons as soon as I figure out if there is supposed to be one or not. Thanks! |
No gasket. |
So the pump bolts to the block with nothing in between? Weird, but ok. I'm disassembling an engine, found rod bearings worn out, a couple lifter rollers scored, and the crank scored as well. Just trying to figure out what happened. Some flakes of stuff embedded in the rod bearings. :( Oh well, guess I need a complete rebuild. |
yes! no gasket!!!!!!!! john |
© 2024 MH Sub I, LLC dba Internet Brands
