LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   LASH for J2K's and Morel's (https://ls1tech.com/forums/generation-iii-internal-engine/436976-lash-j2ks-morels.html)
MOTRUBL Jan 14, 2006 08:45 PM
I've searched like mad and still can't find much. How in the world do I set the lash on my J2K/Morel set-up?? They are the adjustable J2K roller rockers by Jesel, and the Morel's are hydraulic rollers. I've set them cold, but I'm pretty sure I did it wrong. I set them to .020 intake/.024 exhaust, but they kept collapsing the lifter on me. Any ideas before I start up my new motor and have instant damage???
Phil99vette Jan 14, 2006 11:26 PM
I don't think you set the lash @ .020 on hydraulic lifters. You probably should preload them .010-.020 or so.
Phil
Ben R Jan 14, 2006 11:27 PM
Lash or Pre-Load? You can't set lash on a hydraulic lifter, only a solid lifter.
vettenuts Jan 15, 2006 06:48 AM
Recommended preload on the Morel's is 0.030".
What head mods were required for the Jesels, just a spacer or did you have to modify the pushrod holes as well? How much did you have to modify the heads if you did?
SAM98WS6 Jan 15, 2006 08:03 AM
call Jesel and Morel....
MOTRUBL Jan 16, 2006 12:36 AM
I had to grind on the head just above the pushrods so that the rockers would have room to rock. That's it. Stock valvecovers are a no-no without spacers.
MOTRUBL Jan 16, 2006 12:37 AM
Can't locate Morel's #. I've searched like crazy. I could try getting it from Futral.
MOTRUBL Jan 16, 2006 12:38 AM
Sorry. I meant Pre-Load.
vettenuts Jan 16, 2006 08:04 AM
I spoke to Chris Straub on this at length. He knows the Morel lifters quite well, his recommendation was 0.030".
When you modified the head, no mods required to the pushrod holes to elongate them?
QuickSilverTA Jan 16, 2006 09:18 AM
.030 is what im running my morels at
Cstraub Jan 16, 2006 10:24 AM
.030" pre-load on Morels cold as Vettnuts and Quick have posted.
MOTRUBL Jan 17, 2006 12:45 AM
I'm running a .050" shorter pushrod and that's it. I've got plenty of clearance.
Thanks for everyone's help.
Griffin, I may call you sometime before startup on this.
MOTRUBL Feb 1, 2006 07:38 AM
what should I set them at warm??
© 2026 MH Sub I, LLC dba Internet Brands
