low dyno? i have all of the bolt ons...comp cam 232/234 .595/.598, mti stage 2 heads, fast 90/90, flp longtubes, 12 bolt, 3400stall, etc. Dynoed 412rwhp on a dynojet. does this seem low with that combo? car also likes to die a lot, especially after something like a burnout at the track, its been tuned by mti, didnt think it was a cam i should be having a problem idling with? |
seems about right. You need to consider drivetrain loss through an auto with a 12 bolt. Sounds like it is time for a tune-up maybe. |
what would i need to get the 450+hp people are usualy getting from h/c packages. ETPs or AFRs? dif cam? |
i made the numbers in my sig with the same cam. you have aq auto but you have heads and the 90/90 set up. it shouldn't want to die, thats with the tune. what does your car run? thats whats important. |
you would need a m6 or some juice. |
1/8th its run about a 7.05 on a 150 shot, and i think around a 7.6, 7.7 n/a |
does anyone else have something to add? |
412 is good through an auto. What it runs at the track and on the street is more important than a number in my opinion. |
so do those number sound right with my mods |
sounds right to me but you probably need to work more on the tune if u didnt. |
that 3400 stall conveter will also make a "power loss" too along with the 12 bolt and and auto.....but thats an 11sec beast u have!(traction pending of course) |
© 2024 MH Sub I, LLC dba Internet Brands
