Gain from 1.8 Rockers w/Hotcam?
I know this was posted a long time ago but I can't find it.
How much HP would I expect from HS 1.8 rockers with my Hotcam.
I will be putting on home ported heads this spring too.
TIA
TIA
I've seen lots of complaints about the HS and other aftermarket rockers arount here. That's why I've steered clear of them. They are heavier than stock and some have trouble with valve float. If you want more lift, just put in a new cam and get the lift where you want it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
hmm
A few years ago, I got some Yella Terras and they didn't fit under the valve covers but I thought the HS's would be ok. I didn't think about valve float though.
Redneck,
Did you feel a nice seat of pants difference with the intake?
What's this Lithium joke?
Redneck,
Not sure about the Harlands, but the Cranes have a lower rotational mass moment of inertia than the stockers. You can't go by weight alone. Yella Terra has also introduced their new lower inertia rockers as well, haven't seen any results on them yet.
If I were considering a high ratio rocker, I would look at the Cranes, just make sure your springs are up to task.
I believe, although I haven't proven it yet with my own setup (not installed yet), that if you're going to use aftermarket rockers, you need a set of springs that have some headroom and not maxed out. For example, my cam has a .563 lift which is okay with 918s, but add in 1.8 rockers and the lift goes to about .596, so I ordered my heads with PP .650 springs, hopefully preventing valve float as well as being plenty of spring to handle the lift, with room to spare (headroom).
1.8 rocker will be perfect to add axtra lift to your cam. Just get a good set of springs for the added lift. We have seen 18+hp gains and even more TQ from 1.8 ratio rockers.
Nate
I'm calculating .555 lift with 1.8's so would I still be ok with the LS6 valve springs?
Here's a quote from Scoggin Dickey Performance regarding the LS6 springs...
How much "headroom" is good for valve springs?
These LS1 valve springs have an installed pressure/height of 90# @ 1.800”. The open pressure/height is 280# @ 1.250” and the coil bind is 1.160” The max lift of these springs are 0.570”.
This may be one in a million but something to consider.....A guy I met here on the forum has a 01 Z06 with normal bolt-ons, stock cam and swapped to the crane 1.8's and comp 918's. I was at Dynolab with him when he dynoed the car after the swap and he lost 10 hp on the entire curve from idle to rev limiter.
Nate
Nate
Have to agree. Usually any problems that occur on the dyno if aftermarket rockers are installed, it automatically falls upon the rocker as the problem. Everyone jumps on the "its too heavy" band wagon when weight is not the real issue. There is more to the valve train than the rocker. Spring harmonics, wipe pattern and valve lifters all play a role in what is going on. The pushrod can also be a major contributor to problems, but most here are running the better aftermarket thicker walled pushrods. Some springs also don't play well with some rockers and the system excitation that comes from the cam lobe can be a player as well. As soon as you get away from a stock setup, and run into issues, it is necessary to step back and figure out the problem. The higher ratio rockers on this cam have been successfully run by quite a few people from what I have read, and it should be a good setup.
I have a small problem with my setup right now, but I think I have finally figured out what needs to be done to correct it. I will take these corrective actions when I change the heads this spring.
Originally Posted by BadAzz96Z28
This may be one in a million but something to consider..... he lost 10 hp on the entire curve from idle to rev limiter.
FYI there was definitely another factor that caused the loss in power.
Originally Posted by kenkaru
hmm
Redneck,
Redneck,
Why do people even post stuff like this?
I just put the 1.8 Cranes with my Hotcam.I'm getting mine retuned/dyno'd tomorrow morning.I also put on a set of ported Patriot heads as well so the numbers arent going to be just a rocker swap.But for what its worth I'll throw up the the numbers later on tomorrow.
I also think that most of the people swapping rockers just arent getting something right.When I got mine done,it fired right up and I havnt had a single issue with noise/float or any other problem some have.I think alot has to do with lash/swipe/springs.Most people I know just want to throw things together and cut corners.I like to take my time,especially with something as important as your valve train.
I have another question if someone knows?The Cranes come with smaller pushrods when you get the kit.Is it possable that some people buy just the rockers saving a few bucks and install them with the wrong length pushrods.So then this could be causing alot of their problems?Like the Hotcam has the stock base circle while aftermarket cams a different base circle.
LS7 Exhaust Rockers Part# 12579617 1.8 ratio about 8 bucks a piece
I love this board!
Can anyone confirm these will work!?
I love this board!
I love this board!
would my LS6 springs be a no-go with 1.8's?
ls6(405hp)vs the (385hp) ls6 that had the .525 lift. If you buy the Hotcam it
came with the .525 springs. The ls6 heads I bought came with the higher lift
ones. Hope this helps.
