LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   maximum cam lift for 98's (https://ls1tech.com/forums/generation-iii-internal-engine/459195-maximum-cam-lift-98s.html)
rush7 Feb 24, 2006 07:54 AM
With 1998 stock heads/valve covers/all that, is there a maximum lift you can go with on your cam without having to change your covers or heads or whatever? I was thinking there was, but just to be sure...
I want to go with a 224R 116LSA cam from TSP with a .581/.581 lift if it's possible with what I have now.
oange ss Feb 24, 2006 08:33 AM
you have plenty of room with that cam
rush7 Feb 24, 2006 08:40 AM
awesome, thanks!!
H8 LUZN Feb 24, 2006 09:02 AM
The MAX you can run in a stock head motor is the T-Rex cam. Which is MUCH larger than the one you listed.
SUTTERERMAN85 Feb 24, 2006 09:49 AM
its really duration that becomes a prob with cams not clearing, not as much lift
orangeapeel Feb 24, 2006 09:51 AM
It is really a combination of everything...As it is what ultimately determines valve events.
© 2026 MH Sub I, LLC dba Internet Brands
