LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   Camaro won't start looking for help on problem!! (https://ls1tech.com/forums/generation-iii-internal-engine/469-camaro-wont-start-looking-help-problem.html)
blown 346 Jan 19, 2003 04:56 AM
I own a 2000 SS with mods including cam, and I started it 2 days ago to let it warm up. While doing that it was about to die so I gave it gas and it sounded like shit. Then the car blew out brown exhaust fumes and died out. I came to find that the stock battery had crapped out, so i replaced it with a Optima earlier today. When attempting to start it wanted to turn over but it sounds like the cam wont let it. The cam size for support is 222/222 563/563 with a lobe seperation of 114. Any ideas, I'm dying here.
Samba242 Jan 19, 2003 04:10 PM
Re: Camaro won't start looking for help on problem!!
Can you turn the motor over by hand or is it locked up? Any recent mods that could be causing it?
blown 346 Jan 19, 2003 10:46 PM
The motor will turn over just not enough to get it to totally turn over. The only recent mods were,ATI Pro Charger,42 1/2 lb fuel Injectors and a inline fuel pump. Also there was tuning. I have had that stuff for over 3 months and just 2 days ago it started acting up.
blown 346 Jan 20, 2003 04:04 AM
i figured it out!! The injectors are flooding out the motor. I took out the relays for the fule pump and the injectors and let the car sit for about an hour. Then it started for 2-4 seconds until the gas was gone. Thanks for the help. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
© 2026 MH Sub I, LLC dba Internet Brands
