What variables affect cold Valve springs?
I ask this question for this reason: I usually start my cold engine (outside temp. > 60F), shift to Drive, and drive at 1500 RPM or lower until the engine reaches optimum temperature.
Does anything other than RPM influence cold valve springs? I wouldn’t think that engine load would adversely affect valve springs as lift is always the same! Just double checking!
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I always let my car warm up for around 30-45 seconds regardless of outside temps. and then yes, keep the rpm's down. Makes my stomach turn when I see a nice f-body leaving a parking lot 2 seconds after they start their car in december and then bouncing off the rev limiter 8 seconds later.
i guess i'm a stickler for **** like that..because, i too, always let stuff warm up before i rip on it. then again, i drive everything like i stole it, so anything i can do to prolong its life is needed.
