Do these look like 918's? Bought these from a member on here, and was told they were 918's. Well, they were delivered yesterday and this is what I got http://i4.photobucket.com/albums/y14...s/DSC00111.jpg http://i4.photobucket.com/albums/y14...s/DSC00115.jpg http://i4.photobucket.com/albums/y14...s/DSC00113.jpg Now, I know the 918's have the painted blue stripe. These have a grey strip. I looked up the part number 924-16 with crane cams and do not see it. Did a google on it, and found this http://store.summitracing.com/partde...5&autoview=sku The ones I got do not look like the ones in the links. Anyone got any ideas? I am trying to get springs for my TR230 cam. |
This is a 918 O.D.: 1.055/1.290 I.D.: 0.650/0.885 Seat Load: 130@ 1.800 Open Load: 333 @ 1.150 Coil Bind: 1.140 Rate(lbs./in.): 313 TitaniumRetainer: 772,762 SteelRetainer: 774,783,761,787 Cup/Seat: N/A Shims: 4753 |
BTW here are the 915's as well, just so you can compair to what your box says. O.D.: 1.055/1.290 I.D.: 0.650/0.885 Seat Load: 105@ 1.800 Open Load: 293 @ 1.200 Coil Bind: 1.140 Rate(lbs./in.): 313 TitaniumRetainer: 772,762 SteelRetainer: 774,783,761,787 Cup/Seat: N/A Shims: 4753 |
Those look like the stripe 918's have after they've been run in an engine. The blue stripe isn't permanent when exposed to heat and oil. |
920-974 is a number that matches the one you have. http://www.powerandperformancenews.c...Category_Code= dosen't say what it is however. I am sure you could call and ask..... |
Originally Posted by JZ'sTA 920-974 is a number that matches the one you have. http://www.powerandperformancenews.c...Category_Code= dosen't say what it is however. I am sure you could call and ask..... |
That spring # doesn't show up in the LS1 section of the Comp catalogue. |
who was the member and what did he have to say about these same questions? |
Originally Posted by ws6togo who was the member and what did he have to say about these same questions? Orginal PM: I have some 918's with tit retainers.I live in Lufkin 120 miles north up 59. 100.00 Come and get them. Here all weekend. 936-xxx-xxxx Adam Yes that is what they are.They are exact replacement, you can install them with the heads on the car. |
The 924 is at dual spring for a big block chevy. 920 is the outer and 974 is the inner. You have the right springs...wrong box...no biggie. |
Originally Posted by Unaffiliated Racing The 924 is at dual spring for a big block chevy. 920 is the outer and 974 is the inner. You have the right springs...wrong box...no biggie. |
| All times are GMT -5. The time now is 09:54 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
