Torque coming out of my EARS! (cam change)
Originally Posted by vader99
With respect to this experiment, if you took a TR 224 224 563 563 112 +4 cam and changed it to a 110 +4 would you experience more lowend torque as well?
Originally Posted by TopFlight
Good stuff Patrick. How much total timing are you running?
Originally Posted by Grimes
What springs are you using with them? prc duals; patriot duals; 921's?
Originally Posted by Dom
How hard does that cam lope? I also can't wait for the results. I would love a powerfull street cam with a nice top end for the track. This is primary why I was going to go with a 228/228 since I'm not looking for records just a powerful daily street car. I might go with a 110 if you get good results. Make sure to get some sound clips.
What's another interesting comparison is the duration at .200":
The F-13 is 150/148 degrees duration at .200".
My Torque Cam is 150/153 degrees duration at .200", plus I have LOTS more lift. So in a nutshell, I have more curtain area (valve opening under the curve) than cams of larger advertised durations. Gotta love these LSK lobes.
Originally Posted by PREDATOR-Z
How would the XE-R lobes compare to the LSK with a cam of same specs. What would be the effect accross the rpms.?
In short, if you had a XE-R cam with same specs, how would it compare in the power range.??
A 224/228 cam with XE-R lobes has 146/149 duration at .200" (compared to 150/153). The XE-R has .581/.588 lift as opposed to .637/.639. For an XE-R to make comparable power, it would need to be around 230/234 to make the same power.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Patrick..did you have to notch your pistones to run this high lift cam? I have been thinking about a cam with specs a long those lines but not quit as much lift..I too am tired of not making much hp or torque in the lower RPM range..I would really like to have a very quick street car since I go to the track very seldom..and my camshaft makes all of its numbers from 4000 on up
LIFTS HAVE LITTLE EFFECTS ON PTV CLEARANCE > IT IS DURATIONS AND VE'S THAT ONE HAS TO WATCH FOR.
As an example: a 248/258 .500/.500" lift cam would have piston to valve contact.
A 224/228 .750/.750" cam would not.
__________________
How about a 230/234 .640/.642 106LSA 106LC. Wouldn't these specs keep your DCR on target while giving use that cool sounding idle we all crave? Thanks for sharing Patrick.
That cam on a 108LSA with 0 advance would be very nice on the other hand!
#32
Since we are on the subject of lots of overlap and early IVC. What specs do you think we need to achieve that cool idle with lots of mid range power ?
If you want a Billy Badass big duration cam, then a 239/243 .649/.653 108LSA (+1) would basically be a T-Rex with LSK lobes and a little bit tighter LSA. It would give you the excellent mid-range torque (because of good DCR), and will would scream on the top-end. The overlap would be the same as a T-Rex, but it would have about 7% more area under the curve. Itwould still fit under stock heads.
#33
This should be a sticky:
well, Id also like an answer to the question. does this cam require extra clearance added by notching the pistons? or your other cams for that matter?
#36
patrick i wish i lived close to you. i'd pick your brain of all your cam knowledge and be there assisting you in all your setup changes just so i can learn more...i really need a knowledgeable guy to show me some things...congrats on the new setup though...looking forward to seeing a graph
#37
Patrick,
What is your vacuum reading @ idle and what is the minimum needed for descent streetability. I have a vacuum gauge but where do I plug it in to get a reading on my SS?
#39
Patrick,
