Torque coming out of my EARS! (cam change)
#83
Originally Posted by Patrick G
I wanted to maximize the curtain area on the exhaust and keep overlap in check. A 224/234 110LSA cam would have had more overlap at .006" than my current cam. That's why I chose the LSK for the exhaust lobe. Interestingly, Thunder Racing recently made a 223 LSK lobe intake with a 234 XE-R exhaust and mated it with ETP 215 heads. The car made excellent power, even with a wide 115LSA. https://ls1tech.com/forums/dynamometer-results-comparisons/477761-etp-215-h-c-results-pictures.html
#86
7 Second Club
CNB,
The 8-10 degree split is what we have feel will eventually be the best route for the big cc ET heads. Our computer modeling and real world data has said that the big flowing heads need a larger exhaust duration to maximize performance. We consulted with 3 cam grinders and they all said the same thing.
Phil
Phil
#87
Originally Posted by Phil99vette
CNB,
Phil
Phil
#89
Originally Posted by Beast96Z
Exactly the same responses I got too. I was told not to be as focused on the 10 at .200, but more on the 10 at .050" and .006". I agree that the high intake flow and the somewhat normal exaust flow of these heads will require more of a split than the normal LSX based cams.
#90
6600 rpm clutch dump of death Administrator
Intake to exhaust ratio is one of the keys for determining exhaust split. On something with a good I/E ratio you don't need 8-10 degrees of exhaust split. Now, when you look at something like the LS7 head which is a 60% I/E ratio, then yes you start looking at bigger splits.
But, I definitely don't think you need 8-10 degrees on AFR heads.
As for a big cam witha narrow lobe sep. You don't necessarily need to advance those cams. Even with all the overlap, they often make big power. Look at my buddies in Australia.
Pete dyno tested his 408" Ysi at 12 psi of boost with a big cam and a narrow lobe sep day before yesterday (the cam was optimized for a N/A setup). Anyway, he ran out of injector at ~6500 & 12 psi of boost... 920 HP time to move up from 60lb injectors.. The cam they used most folks would not consider as a blower cam. But it still makes crazy power....
#91
J-Rod is right as usual...it's all about the combo that's in your car and your goals. I can understand in theory why certain cam grinders would want a 10 degree split between intake and exhaust, but theory ain't reality. Consider the fact that most of us are saddled with an intake manifold (FAST 90/90) that is known to knock down the flow of even the most spectactular heads, and your intake/exhaust ratio changes dramatically. Now your 320 cfm heads only flow 285. With an exhaust port that flows in the 230-240 cfm range, your exhaust is flowing well over 80% of the intake. There is no need for a 10 degree split when running a FAST intake. Now swap to a sheet metal intake or a well-ported single plane and that 10 degree split would probably make more sense.
My goal was to keep overlap reasonable while maximizing the DCR and power under the curve. By adding an exhaust lobe with a 10 degree split, I would have had to either run a smaller intake lobe or widen my LSA to keep the overlap the same. Both are recipes for decreasing area under the curve IMO. The 4 degree split with similar curtain area for intake/exhaust was a prudent approach to achieve my goals in my view.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
#95
Didn't tony do some testing and conclude that 4-6 degrees was money on the AFR heads?
Tony M.
PS...I know its been touched on but some of the "big flowing" intake ports aren't as big as you think in their actual application (think restrictive manifold designs)....making a blanket statement like they always need 10+ degrees of split might just needlessly give up bottom end TQ with no appreciable gains in peak #'s. Most of the cam guys you are polling are purely looking at flownumbers with a radius plate on a flowbench....not too many of us are actually running our engines that way.....LOL
#97
Originally Posted by CHRISPY
How would you change the cam specs for a 62cc AFR 205 head and completely stock exhaust?
850rpm idle, emisisons legal and pump gas?
................................ 0.006 0.050 0.200
Intake Duration..... - ID 265 215 142 2124 LSK .629 lift
Exhaust Duration... - ED 273 223 153 2127 LSK .636 lift
Lobe Center Angle - LSA 113 113 113
Intake Centerline.. - ICL 113 113 113
Intake Valve opens.. - IVO 19.5 -5.5 -42 BTDC
Intake Valve closes.. - IVC 65.5 40.5 4 ABDC
Exhaust Valve Opens - EVO 69.5 44.5 9.5 BBDC
Exhaust Valve Closes - EVC 23.5 -1.5 -36.5 ATDC
Exhaust Centerline... - ECL 113 113 113
Overlap........................ 43 -7 -78.5 degrees
It's probably better suited for headers than manifolds (because of the later EVO) but it will make TONS of power under the curve.
LSK lobes on intake and exhaust: 215/223 .629/.636 113LSA (+0)
Based on your specs: static compression = 11.15:1, dynamic compression with this cam = 8.82:1
__________________
#100
Originally Posted by ninobrn99
since chris is asking, how would you make it work on a stock head (ls6) motor? full bolton? id like to get an idea of how you'd work it. emissions arent too much of a concern as lift...615 is the max id like to run.
The beauty of the LSK lobes is cramming more duration at .200" lift (which is .340" at the valve). You'd have to admit that more duration at .200" (with the same duration at .050") will make you more power. Add the extra lift and it's a bonus. And I'm not sure where you pulled the .615 max lift number from, but you have to understand, going from .615" lift to .633" is not a huge step. Once you have the correct spring setup, it's all academic.
__________________
