AFR225's Milled 70cc to 66cc
Old Apr 13, 2006 | 11:32 PM
destroyerSS's Avatar
Default AFR225's Milled 70cc to 66cc
just wondering how much compression i gained going from 70cc to 66cc on my AFR 225. And what type of power would be gained
Mods in sig
Also i know it's not much but would going from a 041 head gasket to a cometic .040 do anything at all. With the .041 gasket Quench was .040
Old Apr 14, 2006 | 12:14 AM
ArcticZ28's Avatar
Roughly you gain about .1 SCR for each cc your heads are milled, so you'd be increasing SCR by .6 . Of course to be exact we'd need to know whether your pistons are dished/domed. Nothing substantial at all would change if you changed the gasket from .041 to .040.
Old Apr 14, 2006 | 12:21 AM
Pistons are wiseco flat tops w/ 2 1/2 cc valve reliefs
Old Apr 14, 2006 | 12:56 AM
ArcticZ28's Avatar
Your SCR right now with the .041 head gaskets and 70cc heads should be around 11.1:1. With the 66cc heads it would change to 11.6:1.
Old Apr 14, 2006 | 01:16 PM
NEVRLIFT's Avatar
How much power would he gain from rasing his compression to 11.6? My friend has a 402 with DCR of about 7.8:1. The car still makes pretty good power but he knows that he's leaving some power on the table. We want to raise the compression to move the DCR up to about 8.2-8.3:1. Anybody have any estimates of what he would gain off of that?
Old Apr 14, 2006 | 02:53 PM
NEVRLIFT's Avatar
Anybody?
Old Apr 14, 2006 | 06:49 PM
ArcticZ28's Avatar
I would address DCR with the cam because that is what ultimately affects DCR, not use SCR to raise it. Nonetheless, I would only say the gain would be about 5-10hp, depending how good the tune is.
