ls1/ls6 239 251 grand am cup cam?
Old 05-01-2006, 11:49 AM
cl08's Avatar
Default ls1/ls6 239 251 grand am cup cam?
i would like to run this cam but id like to hear it first anyone got any clips or sounds of it in a f-body
so if any one could help it would be greatly appreciative
thank you
cody
ps i have the z06 valves it requires already
Old 05-05-2006, 04:25 PM
NataSS Inc's Avatar
i just happen to have one if your interested in it. Best way to hear this cam would be to go to www.LGMracing.com and download one of his in car videos from a race. It is the same cam he runs in his GT corvette.
Old 05-05-2006, 04:48 PM
dug
dug's Avatar
Do the pistons need to be flycut? I already have this cam.
Old 05-05-2006, 04:54 PM
NataSS Inc's Avatar
If youre heads have not been milled you should be fine. I would double check for safety though once it goes in though. Even if you already KNOW it will fit, double check it.
And just to add to the original post. The reason for the ZO6 valves is that they are sodium filled (ie: lighter). And this cam is designed to spin some serious RPM. When you get the valves moving like that, they need to be as light as possible.
The one I have is slightly moddified from an original cup cam.
Old 05-05-2006, 05:16 PM
s346k's Avatar
do you have any idea what the personality of this cam is like?
...or are you just wanting something that sounds mean?
Old 05-06-2006, 03:21 PM
NataSS Inc's Avatar
good points.
This cam has a pretty nasty attitude and isnt really condusive to stop and go traffic. Idle will have to be set high and it brings a while new meaning to cam surge.
Old 05-06-2006, 04:08 PM
SVT THIS's Avatar
Isn't its powerband non-existant below 4k RPMS? I'm not sure what the original poster's goals are with this cam but I believe its mainly an AutoX cam. If that's not what your plans are with the car I would look at something else. Someone correct me if I'm wrong.
Old 05-08-2006, 09:25 AM
dug
dug's Avatar
Originally Posted by NataSS Inc
good points.
thats why I bought it.
Old 05-08-2006, 12:04 PM
TAF Motorsports's Avatar
Quick Reply: ls1/ls6 239 251 grand am cup cam?
