How much HP does it take to turn the A/C compressor
Old 05-03-2006, 11:23 AM
snketr's Avatar
Default How much HP does it take to turn the A/C compressor
Why can't it be rigged up like they water pumps are on some cars? They have an electric motor to run the water pump so it's not pulling power from the engine?
With a motor like this???
http://www.grainger.com/Grainger/wwg...?ItemKey=2M191
Old 05-03-2006, 12:07 PM
dug
dug's Avatar
No need to. When you floor it a clutch disengages the A/C.
Old 05-03-2006, 12:10 PM
snketr's Avatar
I'm talking about so it can be relocated out of the way.
Nasty N8's Avatar
Ya it does not run at WOT.
Nate
Old 05-03-2006, 12:39 PM
snketr's Avatar
I know it doesn't run at WOT, I like having A/C on the 100+ days. So, if I can move it and keep it I'm gonna try.
Old 05-03-2006, 12:41 PM
brad8266's Avatar
it is possible to get an AC system that is not belt driven. I do not think it wpould be worth it though. What do you need the extra room for, are you running a turbo??
Old 05-03-2006, 12:46 PM
snketr's Avatar
yes, that is the plan.
Old 05-03-2006, 01:42 PM
GuitsBoy's Avatar
Ill bet it takes quite a bit of force to turn the compressor. It would probably require a pretty big motor, and therefore would put a large strain on the laternator. From what ive heard, car a/c's are between 20,000 and 50,000 BTUs. Thats much more than a household unit.
Old 05-03-2006, 01:44 PM
brad8266's Avatar
an electric compressor will require a lot of amperage to keep it running.
Old 05-03-2006, 01:45 PM
brad8266's Avatar
Well you gotta give up comforts to go fast!! It probably would not be worth it to spend all the extra $$ to get a modified AC system.
Old 05-03-2006, 02:13 PM
snketr's Avatar
Civic Hybrid
The final benefit of a hybrid is that the gas engine shuts off when you come to a full stop, thereby saving fuel. In the first Civic hybrid, if the air conditioning was on and the econ button was not engaged, the engine wouldn’t shut down. This latest hybrid solves that problem by adding an electric-motor-driven portion to the A/C compressor. So, at a stop, the electric compressor keeps the cabin cool. As soon as you lift your foot off the brake, the gas engine whirs to life again.
Just found this
http://www.fisherelectric.com/f_elec...hicle_tech.htm
Quick Reply: How much HP does it take to turn the A/C compressor
