Close to 500rwhp with ported heads? I'd like to think so...
Originally Posted by JL ws-6
That's funny, because teh junky headed 383 that's making 492 to the tires is runnign thru 1 7/8 headers, into an ory without a merge collector, and thru a LM. Pretty much dissolves that argument.... I repeat, an ORY and a LM isn't gonna hurt power.
Brandon
Race your car!
I hear what you are saying... but I can tell you this, they unbolted the Y on his car, so it was open headers to see what that would get them, and it was a 2 hp increase, going from an ORY and a LM to open headers... making the point I was trying to make that the power differnence is so small going from a ory and a Lm to something with a cutout vs the gains that he will most likly see by swapping the intake, that I'd worry about the intake before the exhaust. doing soemthign with teh exhaust in his case, probably good for 5 hp I'd figure. Changing the intakse stup, probably more like 20. I'd go for a 20 hp increase before I worried about a 5 hp increase, that could be the weather that day.
Of all the catback setups out there, the LM has got to be the best flowing that there is, better then a mufflex setup with a muffler, better then any of them. It is the loudest, which means the least restrictive period. Changing that isn't gonna get you very far I'm sure of it.
I understand where you are coming from, but we are talking to different things. Yes a LM flows well, but it does not flow as much air compared to 3" duals or a 4" mufflex. A LM is loud because it doesnt have a muffler, it has a resonator. I agree on the intake as well, but they will both show gains. Is the 383 stroke or bore? Makes a difference.
Race your car!
383's a stroke motor. If it was a bore motor, I'd see how it's hitting the #'s that it is.
I know that 2 3 inch pipes are gonna flow more then a single 3 inch pipe, I just don't think the power levels we're talking about are being choked with the single pipe.
I'm in the process of a buildup myself, if someone wants to prove me wrong and fab a dual 3 inch setup for my car to disprove what I'm saying, I'd be all for it... and would be happy to pay for it after it's done if it makes more power, I just don't think it will, not enough to justify spending a grand on a header back exhaust setup that runs to the back of the car.
I would think with an M6 you'd hit 500 easy with ported heads and a FAST 90/90. I would investigate using some different castings though as someone else pointed out instead of investing alot of money in those. You know your going to want them sooner or later. Might as well do it now and save the money.
Nah, won't be getting aftermarket heads at any point. These are my last expenditure for the engine, other than 90/90. This is a daily driver so it needs to stay streetable. I've just been looking for the 500 mark for a while so this is basically my last hurrah as far as power goes. Then this car will become show and I can move on to my next high hp daily driver project
Thunder Racing got 451rwhp out of a 99 T/A with stock heads and shortblock, LS6, ported tb, and a 12 bolt rear with a T-Rex cam. The dyno graph and a 1/4 tun are both posted under the T-Rex cam. http://www.thunderracing.com/catalog...&vid=3&pcid=51
With a good dyno tune, I can't see 500rwhp being out of reach with well worked LS1 castings even on a rebuilt 346 CI motor with 11:1+ compression.
Jason
Jason
ArticZ, your car sounds killer in that old video clip you posted up after you got the 408 back! Where do you plan to put the second cutout? My only one is just under the rear passenger seat.
