ideal valve terain set up for g5x2?
g5x2 on 112
comp 921 kit
comp hardened 7.4 push rods
whats the hp drop off?
any fly cutting needed?
should i go with a diff length push rod?
should i get new lifters? and new rockers?
i can get teh cam, spring kit and push rods for $500 about 12k on it
and installed for another $500. should i jum on it?
comp 921 kit
I think you should be fine - yes - have the guys check. I've got a 99 LS1, AFR 205cc w/ 59cc mill, .040 Cometics and the G5X2. Hardend pushrods - yes, Comp921s - yes, flycut - no
Yes - get the cam - it is a great dragracer cam. Its lumpy (mine's on a 114), but streetable. BTW - you'll want a tune - this is not a cam to just throw in.
your heads are milled .040? and yours clear so im sure i wont have a problem.
do u have a dyno graph?
whats it peak at how much hp/tq did it make and what are your shiftpoints
Originally Posted by bad6as
whats the powerband on this cam?
aprox yes, explane more....
