LS6 heads better than nothing?
Old 05-17-2006, 04:04 PM
killaz's Avatar
Default LS6 heads better than nothing?
Thinking of getting some heads. I have a spring kit, and was thinking of getting some LS6 heads. Im kind of on a budget, (around 500) so would LS6 heads be better than my stock 2000 heads?
Old 05-17-2006, 05:24 PM
eamador11's Avatar
Do at least a stg I port job on them...
Old 05-17-2006, 05:28 PM
SOM02WS6's Avatar
The LS6 Heads ported with a cam are making good numbers on a budget and they can sometimes be had for pretty cheap. They make good power too...
Old 05-17-2006, 05:35 PM
Kounsy's Avatar
i have a stage 3 ls6 cnc ported heads on my 402
Old 05-17-2006, 05:42 PM
slow trap's Avatar
i would save up alittle more and get a set of the budget ported ls6s and you can troll the for sale section and find you a good deal on a slightly used cam.better to do it all at once than to have to tear back into it not much later on.
Old 05-17-2006, 05:43 PM
santiago's Avatar
I just put a set of stock ones on and I felt a pretty good difference over ls1 heads. I think it was worth it for only $500
Old 05-17-2006, 05:46 PM
Moderator
davered00ss's Avatar
They flow better & increase compression. Great for the price.
Old 05-17-2006, 05:47 PM
Redneck Z's Avatar
If you can save up $900, you could at least get the PRC LS6 heads.
Old 05-17-2006, 06:51 PM
Moderator
then you still need to change the springs.
Moderator
Never mind, I see he has the springs.
