new to ls1's, but...
Old Jun 29, 2006 | 03:12 PM
TruDualed95Z's Avatar
Default new to ls1's, but...
whats the name of that cam that runs great on stock heads/headers? i could have sworn i read something about a cam that produced real decent numbers on stock headers/heads.
thanks!
Old Jun 29, 2006 | 04:02 PM
dyls1's Avatar
CheaTR?
Old Jun 29, 2006 | 04:43 PM
PREDATOR-Z's Avatar
CheaTR, GT2-3, my custom cam, there is plenty out there.
Old Jun 29, 2006 | 05:24 PM
sweet. with that cheatr cam im assuming youd probably need some better springs? could you get away with oem stock repacement springs or no? what sort of lift does the cam see?
Old Jun 29, 2006 | 06:46 PM
Camaro Rick's Avatar
Some say they feel uncomfortable running the OE springs with the stock cam. I'm beginning my research for a cam down the road and from what I've gathered, you'll want to replace a little more than just springs. Also, If you have a 98-00, Most say swapping out the oil pump and timing chain is good to do while you've got everything pulled apart.
And in reguards to the CheatR cam. Thunder Racing sells it and Do a search on this forum for it. There's days worth of info on that cam and others like it. Trust me, I'm still trying to read/retain all the info.
Rick
Old Jun 30, 2006 | 02:33 AM
PREDATOR-Z's Avatar
That is a LSK/XE-R lobed cam, needs duals for sure (maybe shimmed as well, but I know some run it unshimmed with PP/PRC duals)
