Ticking from driver's side of engine bay This has been going on for a month now and is driving me crazy. I have to have my window down in order to hear it. The best description for the sound I can think of is two pieces of plastic quickly hitting each other constantly. The location is hard to pinpoint but it sounds like it's coming from the driver's side front wheel well/where the a-pillar ends towards the front of the car/driver's side header bank area. when it does it (or when I can hear it over the exhaust): 2500 and up RPMs, part/half throttle, with the car in gear it does not do it: at idle; in neutral or park while revving I've had two shops tell me it isn't an exhaust leak after looking it over, and a third didn't even hear it at all. |
Originally Posted by Cobra Commander This has been going on for a month now and is driving me crazy. I have to have my window down in order to hear it. The best description for the sound I can think of is two pieces of plastic quickly hitting each other constantly. The location is hard to pinpoint but it sounds like it's coming from the driver's side front wheel well/where the a-pillar ends towards the front of the car/driver's side header bank area. when it does it (or when I can hear it over the exhaust): 2500 and up RPMs, part/half throttle, with the car in gear it does not do it: at idle; in neutral or park while revving I've had two shops tell me it isn't an exhaust leak after looking it over, and a third didn't even hear it at all. |
Is AIR still connected? |
Originally Posted by BigDaddyBry Is AIR still connected? |
had a similar prolbem with ticking... turned out to be a worn out pully a nice trick my dad showed me for pinpointing a noise is to take a solid rod and lay it on random objects (with your ear to the end)... you will know when you find the source good luck |
Originally Posted by 00transamnh a nice trick my dad showed me for pinpointing a noise is to take a solid rod and lay it on random objects (with your ear to the end)... you will know when you find the source |
it culd be a spark plug or plug wire has come loose. |
is it really loud or could it be described as sounding just like an exhaust leak? |
Originally Posted by 00transamnh had a similar prolbem with ticking... turned out to be a worn out pully a nice trick my dad showed me for pinpointing a noise is to take a solid rod and lay it on random objects (with your ear to the end)... you will know when you find the source good luck nice tip-thanks :) |
Originally Posted by Cobra Commander Yes.. |
Originally Posted by BigDaddyBry AIR plus LTs can lead to a fluttering/ticking of the one way check valve. Block it off and you'll see if this is the problem. |
i am havin the same problem my trans am is the shop for it the same side they said that a rocker had came loose from the bearing which i dont believe |
Mine turned out to be a weld on the header collector that wasn't finished. I had to get that fixed and the tick went away. |
| All times are GMT -5. The time now is 07:37 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
