pat Stg 3 and 224/224/112
Any idea how much power can be made with patriot stage 3 heads, 224/224/112 cam lid and headers? I've made up my mind about the cam and now I see for an extra 16-1700, I can go ahead and have the heads installed. I hear the cam only is good for 390 rwhp with a good tune.
thats what i dont understand!! it seems like everybody says go big, go big, but then on stock heads the little 224 puts just about as much rwhp and tq as a big cam? some guys with huge cams get like 370tq with a cam way bigger than a 224 but a 224 puts like the same tq or maybe slightly more?
Originally Posted by Rescue Ranger
I'm sure Gunnar from Patriot himself will tell you the S3 heads are far too large for your stock cube motor. You'll probably lose some power with those, or gain very little. Go with the Stage2 59cc and that 224 and you'll make the same power roughly that I do
A big cam with stock LS6 style heads and headers will usually top out on the dyno around SAE 425-436rwhp. You get to a point where you just can't flow anymore air through the heads just sitting on the dyno. An experienced tuner will leave you slightly rich, so some gain will be felt out on the open road. A head change will be needed at some point to support a big cam with alot of lift, but there are limits to cam selection without flycutting. On a 346ci., there are a few things to look for where bigger isn't always better. Valves. The stock size valves are more than sufficient on a 346ci. in terms of air velocity. Anything larger will sacrafice some flow velocity. A 215cc/80cc head is going to make alot of power on a 346ci. The heads can be taken further, polished and milled, but the D shaped exhaust port should be virtually left alone. You can blend the bowls, port the exhaust runners, but the D shaped exhaust outlet should be cleaned up only. This maintains good outlet velocity. I've seen guys port the heck out of the exhaust port, and wonder why torque falls on it's face.
The intake port cannot be big enough, Here is where bigger is better, as long as you have enough the fuel to support it, this is where power is made.
Originally Posted by RealLiveMD
So... that would be about 430 with heads?
The stage II head would be largest head to go with in this case. Our CNC ported 243's would also be a good choice. They are available for a slightly less price with the OEM 2.00"/1.55" valves. Either of these heads will be better for your combo that the stage III heads.
