Tell me what you think please!
Old 08-01-2006, 04:33 PM
camscam02's Avatar
Default Tell me what you think please!
IM going to be doing a cam job soon! this is my idea and tell me what you guys think about it please!
Comp cams 224/228 .581/.588 114lsa!
PRC springs
hardened pushrods
ls6 oil pump
ls2 timing chain!
Sound good? bad? ne suggestions would be greatly appreciated it is a daily driven car with full boltons and 3500 stall! nitrous to be coming!
Thanks!
Old 08-01-2006, 07:17 PM
sprydncamd ta's Avatar
sounds good i like my f-13 cam personally but either way if it was me id do it on a 112 lsa
Old 08-01-2006, 08:25 PM
Jed Z06's Avatar
Get a bigger cam.
I really believe you will want a bigger cam within a month or so.
Old 08-01-2006, 08:52 PM
98hardtopZ's Avatar
agreed....go bigger....
Old 08-01-2006, 08:56 PM
camscam02's Avatar
i have to pass smog in CA or i would do a bigger cam for sure! like g5x3! whats the biggest smog friendly cam?
Old 08-02-2006, 11:53 AM
dnm12's Avatar
i live here as well in CA that is and i love that cam it has plenty of room for heads to improve it, check out my website with my mods 372/372 to the wheels in 100º heat on a chasis dyno, with P&P ls6 heads dynoer claimed well over 400 at the rear the cam is just waiting, and seat of pants difference is insane
Old 08-03-2006, 02:28 AM
Lethal_Ws6's Avatar
hey man (2kws6) from sacfbodyz,.. thats a good cam, but there is room for bigger..theres ways around smog. . .
And dont forget your bolt and gaskets kit, and also a ARP longer crank bolt
Old 08-03-2006, 02:44 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Originally Posted by Jed Z06
Get a bigger cam.
You need a bigger cam.
Old 08-03-2006, 08:46 AM
GuitsBoy's Avatar
Id get a bigger cam if it were possible, but since you have to smog the car, id check to make sure you can pass with that cam. Many think that the 224/224 is pretty much the limit.
Old 08-03-2006, 02:11 PM
camscam02's Avatar
i def, agree that i bigger cam would be better no doubt in my mind! but the fact of not passsing smog is in the back of my mind and its a daily driven car! ps i can get all the gaskets and bolts easy my dad works for a chevy dealership!
Old 08-03-2006, 04:17 PM
dnm12's Avatar
dont listen to them a set smog legal heads and your looking and consistent snake eyes, who can beat that for 21MPG????
Old 08-03-2006, 04:27 PM
STANG KILLA SS 2's Avatar
dont waste your time with that baby cam
Old 08-03-2006, 09:53 PM
The1N_only's Avatar
just get you some 205 AFR's and that a 224 cam on a 144 and you'll make good power and pass smog.
Old 08-03-2006, 11:20 PM
camscam02's Avatar
ok then give me the biggest cam that you know that had passed smog legitmaley!
Old 08-04-2006, 12:14 AM
Jorge Olmos's Avatar
PRC springs
hardened pushrods
ls6 oil pump
ls2 timing chain!
Thanks!
Put a set of good heads wile you are at it
Patriot Perfromance LS6 with 64cc on sale now until Labor Day $1095 or
Go with with AFR 205 (67cc) these heads flow just a little better than Patriot
I/E ralation@.400 lift AFR is better
Old 08-04-2006, 12:25 AM
224/228 its good, gives you alot more ***** without really sacraficing driveablity
But for real big ***** go big, make sure to ask these guys about Piston to Clearance
Old 08-04-2006, 12:27 AM
RoastEmSS's Avatar
dont tell that to patrick G
Old 08-04-2006, 01:31 AM
camscam02's Avatar
i would love to do both right now but only have the money to do cam only and iin november or so i will be putting heads on it!
i pretty sure there is not a clearance problem! but im not positive so do you have tyo notch with this cam?
Old 08-05-2006, 12:15 PM
camscam02's Avatar
bumped
Old 08-05-2006, 02:13 PM
GTOtoGO's Avatar
I have the TR224 on a 114lsa. I can pass smog on the machine, but like you not the visual (headers). Synergy says they can tune to pass the cam you are looking at. Who are you going to use for tuning? You should make a good daily driver with that cam. The 114 will still lope and you should be able to keep the idle at stock or very close.
Good luck
