Lpe Gt-7 Anyone use this cam. Seems like it might be a sleeper kinda cam. |
We have installed it a couple of times. If you like the LPE stuff, I like the GT2-3 better. |
Eh, the GT2-3 didn't move me in anyway. Is the GT7 comparable to Thunders Cheater cam? |
GT11 looks promising |
That GT1-1 looks f'ing BEAUTIFUL! 229/242 duration @ .050 .631/.631 Only problem I see is that it's on a 114 LSA. |
Originally Posted by N4cer That GT1-1 looks f'ing BEAUTIFUL! 229/242 duration @ .050 .631/.631 Only problem I see is that it's on a 114 LSA. Also would the GT1-1 would also be a good blower cam? |
Other than the GT1-1, I can't see that any of the cams are very big. I'm not sure on a blower cam. I know they usually have a wide LSA, but I don't know lift and duration for blower cams. |
From all the talk on the truck page, the Gt2-3 cam is good because of the lower duration but big lift. that cam runs awsome in my truck with other bolt ons and tuning. |
I did 368/360 with the GT2-3 in my GTO. Mods at that time were long tubes/cats into the stock cat back, CAI, pulley, thermostat, and tune. Should easily be more with the normal bolt ons and less drivetrain loss of an F-Body. Idles smoother than stock so you'll never even know its there :) |
the lpe stuff is great for FI. the gt2-3 is a good cam to get now and then put the blower on later down the road. I would probably use the gt2-3 if you are going FI or look at EPP's blower cam that they have out. Usually higher lsa is easier to tune with a FI setup. |
Good info, but - I want a cam with great NA power, but also be blower friendly. GT2-3 is good, but not enough for me NA. Thats why I was asking about the GT1-1. |
207/220 571/.578 w 1.7 rocker 118.5 CL You call that big lift? |
Originally Posted by N4cer 207/220 571/.578 w 1.7 rocker 118.5 CL You call that big lift? |
OH yeah it has its place. But the guy said it has big lift. It doesn't. |
© 2024 MH Sub I, LLC dba Internet Brands
