Interpret/compare these Valve Events...
Baseline Cam (actual dyno data):
HP Peak: 5700rpm
Tq Peak: 4500rpm
(LSA 111.5+2, XE Lobes, .559" int, .564" exh)
--------.006----.050----.200
Int Dur...267.......214......133
Exh Dur..273.......220......138
IVO........24.......-2.5
IVC........63.......36.5
EVO.......70.......43.5
EVC.......23.......-3.5
Overlap...47........-6
Compare these two (below) to the Baseline specs above.... I realize the differences are subtle (Option-A is basically identical at .050"), but how would the HP and Tq peaks change, and by how much (as a guesstimate)? Would the torque/power "hold on" longer or shorter after their peaks for Options (A) and (B) when compared to the Baseline? What else do you "see"?
Option (A):
(LSA: 112+2, XFI lobes, .600" int, .590" exh)
Int Dur...264.......214......139
Exh Dur..270.......218......141
IVO........22........-3
IVC........62........37
EVO.......69........43
EVC.......21........-5
Overlap...43.......-8
Option (B):
(LSA: 112+1, XFI lobes, .600" int, .590" exh)
IVO........21........-4
IVC........63.........38
EVO.......68.........42
EVC.......22.........-4
Overlap...43........-8
Thanks so much!!
Of course, this is all speculation and would really depend on the rest of your combination.
Edited my original posting to include the durations as well. Should've had that in there the first time.
Also, Option (C): (LSA 113+2, XFI lobes, .600" int, .590" exh)
EVO.......70.........44
EVC.......20.........-6
Overlap...41........-10
I'm looking for something that would mimic the Baseline cam as much as possible (ie, peaks at same spot or *slightly* earlier, but with gobs of low-end torque) but also hopefully holds the torque a bit longer before falling off - when using a slightly smaller duration cam (214/220 baseline to my 214/218 "Options") & also more aggressive lobes (XE Baseline to my XFI-spec'ed "Options").
Intake Lift: .559"
Exhaust Lift: .564"
Duration at .200": 133 int, 138 exh
The "Options" XFI:
Intake: .600"
Exhaust: .590"
Duration at .200": 139 int, 141 exh
BTW, yep the heads flow well up to .600" lift.
