looking for a little help removing k member
i know that i will have to support the engine somehow
i am thinking either with a metal bar from the strut towers and then a chain suspending the engine, or a jack under the very front of the transmission...
but what all is involved in pulling the k-member?
any detailed guide on removing with leaving the engine in?
i know i will have to unbolt the motor mounts...and from there i am looking for other useful bits of helpful info...
thanks
Louie
Paul
Paul
thanks!!
that is exactly what i was looking to hear
Thanks again!
Paul
i cant get the a-arms to break free from the kmember...
the vertical bolt is unbolted(un nutted) whatever you wanna call it, but that bolt will not come out in either side, and the horizontal one, i cant get the bolt out because the steering is in the way...
what am i supposed to do about it?
thanks
Louie
Install a STB if you don't have one.
Take tie down straps and secure the motor to the STB
Now you can unbolt the motor mounts and drop the K-member.
That's exactly how I did it in my '94 and worked great.
i cant get it to come apart from the a arms and i am not too sure how to completely remove the a arms to come with the kmember either...
Please check my post right before this one and let me know what you think
thanks
Louie
EDIT: youll have to undo the two power steering line that go from the resevoir to the rack and the return line also.
Everything is done, except for the brake lines and the strut bolts...
what do i have to take out to get the struts out?
the two nuts and two torx on the top? or something else?
Thanks
Louie
