05 GTO A4 Cam Question Yeah, I know it's an LS2, it's in the wrong section. Well way more cam info gets throw around over here. 05 GTO LS2 A4 Yank 3600 Stock 3.42 Gear SW Long Tube 1 3/4" headers No Cats Custom exhaust, x pipe, Magnaflow mufflers Volant Intake Ported Stock Intake Manifold Ported Stock TB Underdrive Pulley Question is will this be an optimal cam if I end up getting the PRC 5.3L 2.5 Heads? 228/232, .588/.592 114+4 on XE-R Lobes Also can or should I deck the heads at all. Or run a thinner head gasket Car is DD, fun street car, it'll see the track maybe 2-4 times a year (not a priority) TIA |
I would use a 112 LSA and 2* advance, rather than the 114 You should be able to mill the heads a bit and go a 11:1 CR, just ask when you buy them. |
© 2024 MH Sub I, LLC dba Internet Brands
