Rough idle pissing me off........
I purchased a stock 99 FRC (with 47k miles) a couple months ago and lately have noticed when it gets warm it has a very noticable shake at idle. I put in new TR 55's, MSD wires, cleaned the TB and MAF, 2 tanks of lucas, and sea foamed. This past weekend I had a tuner hook it up to his laptop and everything look good. Does anyone have any idea what could be causing this?
It doesn't surge or anything abnormal when at any RPM other than idle. When I pull up to a stop light the car the car just has a very noticable idle to it that even the wife asks what it causing it to shake. I have only put about 1500 miles on it, but I am pretty sure it wasn't doing it when I purchased it.
Originally Posted by Ragtop 99
Is your car an automatic? They have really low idle speeds. bumping it 50 rpm helps.
I've also seen a 1/2 turn of the idle set screw help. Did you mess with it when you cleaned the TB?
The car is a 6 speed and I am pretty sure there isn't an idle set screw. When I had it at the tuner he also checked everywhere for vacuum leaks and found none.
Originally Posted by justin1889
I purchased a stock 99 FRC (with 47k miles) a couple months ago and lately have noticed when it gets warm it has a very noticable shake at idle...
