Please help: lterms are lean : O2's are rich how is this possible?
But, at wot the O2 are rich .9 - .94. I don't understand how i can be lean at cruise and rich at wot. If i installed the stock maf, wouldn't i be even more rich at wot? Could the risistor in my air temp throw off the readings. Does any one else have the same problem or have seen anything like it? Finally, would it be worth it to buy a maf translator? Please help
Marco
Just a FYI, having a dead O2 sensor will do the same thing on the bad bank but you would see that in your O2 readings. The sensor would read .450mv or thereabouts at all times.
