Cam/head guru's check this out What do you think about this setup for street, MN6 with 3.90's. Thank you. aaaaaaaaaaaaaaaaaaaaaaaaaaa .006 .050 .200 Intake Duration ID (1st number) 283 230 155 Exhaust Duration - ED (2nd number)291 227 163 Lobe Center Angle (LSA) 112 112 112 Intake Centerline - ICL (LSA - degrees of advance e.g. 114+2 = 112) 108 108 108 Intake Valve opens - IVO 33.5 7 -30.5 BTDC (- indicates ATDC) Intake Valve closes - IVC 69.5 43 5.5 ABDC Exhaust Valve Opens - EVO 81.5 49.5 17.5 BBDC Exhaust Valve Closes - EVC 29.5 -2.5 -34.5 ATDC (- indicates BTDC) Exhaust Centerline - ECL 116 116 116 Overlap 63 4.5 -65 Bore 3.9 ST = Stroke 3.622 RL = Rod Length 6.098 Number of cylinders 8 Deck Height (how much pistons come out of the hole) -0.006 Piston Dome or Dish (- for a dome + for a dish) 0 Compressed Head gasket thickness 0.04 Cylinder Head Chamber Volume 63 Static Compression Ratio 11.18 :1 Dynamic Compresion Ratio 8.55 :1 Rod to Stroke Ratio 1.68 :1 Bore to Stroke Ratio 1.08 :1 __________________ |
Alright, do I need to post more info. Let me know what to provide. The link is safe and to an excell shreadsheet on my server. :lurk: |
I edited the data into the first post. |
Looks like a great cam to run with factory heads and LS6 intake. Thunder Racing has been selling that cam for about 5 years. It works great. |
Originally Posted by Patrick G Looks like a great cam to run with factory heads and LS6 intake. Thunder Racing has been selling that cam for about 5 years. It works great. |
| All times are GMT -5. The time now is 12:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
