LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   surging problems w/ RPM's (https://ls1tech.com/forums/generation-iii-internal-engine/63859-surging-problems-w-rpms.html)
Slow346 Mar 4, 2002 08:02 PM
ok i have dynatech headers, 3200 vig converter and ever sence ive put on the headers when at an idel the car surges in the rpms almost like its caming or something. sometimes if i give it a little gas and let off the car rpm will drop so low it kills the car. freinds of mine say it might be the TPS sensor. What do you guys think is the problem. any ideas would be helpful.
Slowhawk Mar 4, 2002 11:28 PM
Re: surging problems w/ RPM's
Did you do any A/F adjustments for the headers?
It could be way off.
On my FLP's,I had to richen up the base 15% and WOT 2%.All done with a MAFT.
A quik way to tell if it's lean.Turn your Mass air meter backwards.It will richen it up a little.
© 2026 MH Sub I, LLC dba Internet Brands
