Shimming 918's w/stock cam. Y/N?
I'm installing a set of 918's on a stock 00 LS1 with a Vortech. Will be turning 63-6400ish at ~7psi boost. I've been reading up on shimming the springs and most people recommend shmming a spring up to within ~.050" of coil bind. If I figured correctly that's .153" of shims.
Something doesn't seem right.
1.800 installed height
.497" lift
1.100" coil bind
0.050" clearance
So do I shim or not? Thanks.
.497" lift
1.100" coil bind
0.050" clearance
