5.3l heads with T1 cam?
Old Mar 10, 2002 | 06:50 PM
Scalpel's Avatar
Default 5.3l heads with T1 cam?
Should I go with a set of ported/polished 5.3L heads w/my T1 cam as opposed to porting the 5.7L heads. I do spray occassionaly but I have access to good gas, 93-94 octane. I feel that I could benefit from both the higher compression and good flow. This is my daily driver, BTW. <img src="gr_grin.gif" border="0">
Old Mar 10, 2002 | 09:50 PM
LEO's Avatar
LEO
Default Re: 5.3l heads with T1 cam?
I've got a similar combination. 5.3l heads with the C1 cam - it's my daily driver and I've put 30K miles on it with no problems. I run 93 oct. I think you'll be pleased with your combination.
Old Mar 11, 2002 | 11:50 AM
Scalpel's Avatar
LEO, did MTI port those 5.3L heads? If so, do you mind telling me how much you paid for them? Thank.s
Old Mar 11, 2002 | 06:03 PM
Jantzer98SS's Avatar
The 5.3 heads will help to a point. Higher compression will give you more low-mid range power and better fuel economy on the street, but you're limited to how high you can go based on your cam selection and gas octane. It's too much of a PITA to be looking for 93/94 all the time, so keep the compression reasonable. With a T1 I'de shoot for 11.1 or 11.2, but not much more for a daily driver. The other advantage to the 5.3 heads is you can unshroud the valves better while keeping the compression up. With larger cams in the 226-229 range I might try 11.3 or 11.4. You'll see more benefit with large cam applications, so really that's their best use.
