valve spring question....real technical q's on my ls1 heads i wanna run a double spring...but while at the machine shop they opened up the spring pockets for the bigger springs...and all of them feel like the walls are paper thin...and on one they broke though....SO I NEED SOME HELP...this was done on an spare head so i need to get some help on what double springs i can run and how big they have to open up the spring pockets??would it be any different on the ls6 castings?? can some one help?? |
Re: valve spring question....real technical q's My old school Chevy head answer would be to lay a .030" shim on head(or thicker) and cut pockets like that, if that leaves spring not enough installed height(too much pressure) than you would have to use longer valves or retainers?keepers that would give more installed height. It would be wiser to use double spring that will fit in inst. height with shimmed seat cut though.. |
Re: valve spring question....real technical q's </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CAMN HAWK: <strong>would it be any different on the ls6 castings?? can some one help??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LS6 castings are even worse. They puch through before an LS1 casting will. Call MTI and ask them which double spring they are using. Why do you want to go double? A 918 wont work for you? One thing about doubles is that some are too strong for stock hyd. lifters and they'll collapse. Brad |
Re: valve spring question....real technical q's I am running Comp 987 springs. I ran a set of 977 doubles before but they are kind of tall. |
Re: valve spring question....real technical q's thanks guys ....i think i have it figured out.. |
| All times are GMT -5. The time now is 06:48 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
