LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Generation III Internal Engine (https://ls1tech.com/forums/generation-iii-internal-engine-5/)
-   -   What's your oil pressure with A/C on? (https://ls1tech.com/forums/generation-iii-internal-engine/65679-whats-your-oil-pressure-c.html)
CamaroSS_2002 Jun 15, 2002 02:43 PM
I noticed mine drops to around 40psi earlier today temp gauge was at 210 and I turned A/C on and it droped to about 30 for a sec. I run mobil one and I'm about due for an oil change, is this normal? I don't run the A/C much.
btw PSI is at idle.
Jax White TA Jun 28, 2002 01:24 PM
Re: What's your oil pressure with A/C on?
The slight drop for a sec was due to the instantaneous strain placed on the motor by the a/c drive belt. The PCM will compensate for this and increase the idle speed bringing the oil pressure back up. Nothing to worry about.
Dan
© 2026 MH Sub I, LLC dba Internet Brands
