What are the biggest cams A4's are running? I may be changing my mind for the 100th time on what cam to get. With all these huge cams starting to come out, which ones are A4's using, is idle/drivibility a problem w/ LS1Edit tuning, whet #'s are they putting out. What "drop in" springs would be the most reliable with a high lift? I did a search, but I read mostly about M6 guys with the big 'uns. I would like to hear from A4 people. I'm looking real hard at the MMS229 114lsa. |
Re: What are the biggest cams A4's are running? I'm happy with my setup. Comp 941's here. |
Re: What are the biggest cams A4's are running? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Terry Burger: <strong>I'm happy with my setup. Comp 941's here.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What do you have your idle set at, and do you get much surging? Also, I know you're a MMS guy, so what do you think about the cam I mentioned? I want it to be a good match for my Vig 3200, though I may step up to a TP4400 at a later date. |
Re: What are the biggest cams A4's are running? you got a personal message. steve frank |
Re: What are the biggest cams A4's are running? look at my sig for what i'm in the process of installing. Chris is running the same thing so maybe he'll step in and give some info. |
Re: What are the biggest cams A4's are running? I just put a 226/234/114 in my C5 A4.We are still working on the tuning but it sounds awesome through the new Corsa Ti race exhaust with a 850 idle!!!!! |
Re: What are the biggest cams A4's are running? </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> What do you have your idle set at, and do you get much surging? Also, I know you're a MMS guy, so what do you think about the cam I mentioned? I want it to be a good match for my Vig 3200, though I may step up to a TP4400 at a later date. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have my idle speed at 950 and it pulls ~15" of vacuum at that RPM. It runs nice and smooth, and is really easy to live with. It will work OK with a Vig 3200, but you'll be happer with the PI4400. My best ET on the ST3800 (same stall speed as your PI) was 11.57, best ET on the TP4400 is 10.98. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> |
| All times are GMT -5. The time now is 08:29 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
