WTF just happened? (Don't know exactly where to post this.) I just got done waxing the car, so I started her up to pull her out of the garage. When I start the car, it almost doesn't start, it stumbles a bit, idles just below 1k rpm really rough. I figure I'll give it a little bit more gas. I did and when the rpms came back down it idled just the same. After that I turned the car off then turned it back on a again to see if it that would help. Well when I started it and went to pull out of the garage, the exhaust popped more than usual. After that, it started making this ticking noise on the driver's side of the motor. I left it running for like three minutes, still ticking. Revved a little, still ticking. Anyone have any ideas what the hell just happened? Chris www.geocities.com/ls1z28chris/sig.htm |
Re: WTF just happened? (Don't know exactly where to post this.) You leave any sensors unplugged under the hood? What are your current mods? What was the last thing you did to the car engine-wise? |
Re: WTF just happened? (Don't know exactly where to post this.) Air filter or plug wire pop off? |
Re: WTF just happened? (Don't know exactly where to post this.) </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MelloYellow: <strong>Air filter or plug wire pop off?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Now the first things I looked at were the plug wires. The #7 seems to jiggle around more than the rest, but I pushed that sucker in there as hard as I could and started her up again. The noise is more quite now, but its still there, and it wasn't there before this happened. Click the link I put at the end of my post for my mods. The last thing I did engine wise was change the spark plugs like two or three months ago. Its been running fine with zero problems so far, so I don't see how that could be the problem now, though. :dunno: Chris |
Re: WTF just happened? (Don't know exactly where to post this.) Broken spring? Do you have an aftermarket cam and some cheap spring like a K-motion? |
Re: WTF just happened? (Don't know exactly where to post this.) </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Biochem: <strong>Broken spring? Do you have an aftermarket cam and some cheap spring like a K-motion?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No, I've just got a few simple bolt-ons. I've got the SLP Loudmouth, a Whisper lid, !FRA and a K&N filter. If this helps, the noise gets faster when I raise the rpms. Chris <small>[ June 21, 2002, 10:16 AM: Message edited by: LS1Z28Chris ]</small> |
Re: WTF just happened? (Don't know exactly where to post this.) The ticking is the wet spark plug wire (that's bad BTW) shorting to the engine or whatever <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> |
| All times are GMT -5. The time now is 12:28 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
