Cam break in procedure What is the recommended break in procedure after a cam install? |
The cam won't need a break in, but the springs like to be heat cycled a bit IIRC. |
correct roller cams don't need a break in like flat tappet cams just heat cycle the springs a few times before going above 3000rpm |
Diddo, maybe change the oil after about 500 to 1000 miles in case of new parts seating in. Like new timing chain or oil pump. Just a thought. |
Originally Posted by TheBlurLS1 The cam won't need a break in, but the springs like to be heat cycled a bit IIRC. |
Originally Posted by JRracing Diddo, maybe change the oil after about 500 to 1000 miles in case of new parts seating in. Like new timing chain or oil pump. Just a thought. |
© 2024 MH Sub I, LLC dba Internet Brands
