Starting with C5R block....
9,500 in port work and parts..........
Seems a little fishy, but maybe there is something I am not seeing!
As mentioned before I am getting a set and am interested in how this is all turning out.
<strong>Yes, you absolutely have to have a custom intake manifold for the C5-R heads and yes, I'd go with a larger TB while I was doing it. Neither the LS1 nor the LS6 intake will work.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Excuse my ignorance but... why not?
Good luck. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
BTW I'm gonna have an LS1 engine (2,500 miles), Z06 clutch and pressure plate and complete rear end (4:10) for sale.
Lamar will document the entire build up so if I can figure out how I'll post some pictures when we get started.
You also get a choice of rear end gears in the ZL-1 and since we plan to swap the rear end out anyway it might be a good time to get the right gear ratio for a SS, A4, 1LE with the LS6 engine. Of course we'll do the torque converter at that time too.
I think I'll talk to Matt about just installing his LS6 in my SS, then I'll take the ZL1 to Lamar when all the parts are in and the engine is ready to install.
<strong>Colonel? One larger TB or two smaller? Which would be better? I've seen the intakes done both ways.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Good question, I want to know, too...
<strong> Also, we flowed them against all out LS6 heads and the C5R don't beat them by much and that's at very high RPMs and lift.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That makes Baby Jesus and me cry <img border="0" alt="[whiner]" title="" src="graemlins/gr_cry.gif" /> How much is 'much'? Are those stock C5R heads or ported?
What's different about the exhaust ports? The description in the GM catalog says they are in the stock location compared to a LS1/LS6 head. Are they just bigger? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
So what head do you think your gonna go with? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John
Sounds like a pain in the *** but Lamar and Rob said they can do it. So, away we go!
I wish I had the $$ for something even close to this. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Long live big money hotrodding!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
